Installation & Licensing
FATAL ERROR: Unhandled e0434f4dh Exception at 770cfc56h
2 REPLIES 2
egarcia94526
328 Views, 2 Replies
I cannot open autodesk LT 2012 after update. I get FATAL ERROR: Unhandled e0434f4dh Exception at 770cfc56h when opening a drawing
2 REPLIES 2
afif90
in reply to: egarcia94526
try re-install the Acad or try re-install Net.frame
Thank You&Best Regards,
Autodesk Reseller Malaysia
Mohd Afif
TravisNave
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
