Installation & Licensing
FARO.L.S 1.1.406.58 failed while installing Autocadmap2011
2 REPLIES 2
112178 Views, 2 Replies
hi,
pls help on this issue.
I m getting the  error mesage on FARO L.S.1.1.406.58 while Autocadmap3D 2011 installation. but after ignore the error installation completed successfully (expcepr FARO L.S.1.1406.58). Autocad 3D map 2011 also working.
if any error will occur in future?
 instllation log follows.
2010/12/3:11:06:54 753 GC008 === Setup started on GC008 by 753 ===
2010/12/3:11:12:15 753 GC008 Install DirectX 9.0 Runtime Succeeded
2010/12/3:11:13:40 753 GC008 Install FARO LS 1.1.406.58 Failed Failure is ignored, Result=1603
2010/12/3:11:18:35 753 GC008 Install AutoCAD Map 3D 2011 Succeeded
2010/12/3:11:26:07 753 GC008 Install AutoCAD Map 3D 2011 Language Pack Succeeded
2010/12/3:11:26:25 753 GC008 === Setup ended ===
i have installed by deployment admin image (network license)
note: the above error occurs on systems which autocad map3D 2011 trial version (30 days) already installed. i had removed thro Add r remove and then only installed licensed version.
2 REPLIES 2
hashim.mundol
FARO LS is required for the FARO scanner integration, if you wish to have thi feature, please disable anti virus and try to install this from the installation source (support folder)
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
hi,
Thanks for the clarification.
Administrator Productivity
