• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    FALLA INSTALACION REVIT ARCHITECTURE 2012
    151 Views, 2 Replies
    01-20-2013 06:45 PM
    HOLA, ESTOY TRATANDO DE INSTALAR REVIT EN MI OS WINDOWS 7 ENTERPRISE, LO DESCARGUÉ DE AUTODESK STUDENT Y USE LOS SERIAL NUMBER QUE AHI PROPORCIONAN PERO SUCEDE LO SIGUIENTE EN LA IMAGEN
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: FALLA INSTALACION REVIT ARCHITECTURE 2012
    01-21-2013 11:13 AM in reply to: raviel_10
    Hola,
    Attache su installacion log, por favor.
    Gracias.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    04-04-2013 05:31 PM in reply to: TravisNave
    tengo el mismo problema que el lo instale igual como todos los demas programas y no me deja me sale el mismo error que hago ??
