Installation & Licensing
Extensions for Revit Arch 2012
3 REPLIES 3
374 Views, 3 Replies
I have just installed Revit Extensions on my machine running Win 7. It seems the family files for the Bridges extension are installed into the Public folders (namely "C:\Users\Public\Autodesk\REX\2012\Revit\Bridges\...") However, due to the way my network sharing is set up, I do not want files associated with programs in the Public folders.
If I move the files to another folder, (i.e. ProgramData) I get an error message when using the Bridges extension. Is there a .cfg or .xml file that is referencing these files that I can change?
Thanks.
3 REPLIES 3
david.lau
I think that there is an Options button when you click on the R menu to change the path to another folder.
David Lau
in reply to: david.lau
The options dialog under 'File Locations' that you refer to only lists places associated with the main program, not revit extensions...
david.lau
I have confirmed via the Revit Clinic Team and the Extensions are hard coded and the paths cannot be changed.
David Lau
Administrator Productivity
