Running AutoCAD 2000 / ADLM on a NT server and serving clients on 95 and 98.
My problem is that expresstools were not on the original install of the network server's version of AutoCAD. I ran the "EXPRESSTOOLS" command on the server and it added the menu, the tools all work fine. On the client side the install shows the menu but most all of the commands just generate an "UNKNOWN COMMAND" error. Also when a client is opened initially it displays the following:
Regenerating layout.
; error: bad argument type: stringp nil
I checked the "support file search path" and the expressmenu directory on the server is listed and valid.
Please help.
Jim Wertz
