Look, I've been searching EVERYWHERE for a real and actual answer. I setup a Network deployment, and YES, I selected Install Express Tools. I did a generic setup with default values. It installs perfectly fine and Express Tools respond normally. HOWEVER: as soon as I modified the deployment to look for the EXACT same menu file located in a shared directory instead of the default one, Every tool is not recognized. Even with the shared directory in the support path(s). Is there an arx file or something I can throw in the startup suite to enable the express tools?
And YES, I tried "EXPRESSTOOLS", "MENULOAD", "DEMANDLOAD"=3, etc.... "Use custom folders" is also picked.
This is Acad2012, running on 32bit Win 7
when I try and load an individual command such as "MOVEBAK", I get this in the command line:
"Missing 'acetutil.fas, MOVEBAK not loaded"
Hi, have you verified that AutoCAD is loading the correct acetmain.cuix and not the one in the users support folder, "C:\Users\<user login>\AppData\Roaming\Autodesk\AutoCAD 2012 - English\R18.2\enu\Support?" Another thought, does the acetmain.mnl exist in the new location?
Cheers!
Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker C.
SR Technical Support Specialist, KDE
Autodesk Customer Council | Only One AutoCAD | AutoCAD Blog
I wanted to check back and see if this issue has been resolved?
Cheers!
Volker
Volker C.
