Installation & Licensing
Exported license turns into 60 days trial
7 REPLIES 7
Message 1 of 8
596 Views, 7 Replies
Dear Support,
Why my exported license turns into a trial?
Please see the attached file.
Thank you.
7 REPLIES 7
Message 2 of 8
TravisNave
I fail to see a problem.  Why are you using the LTU anyway?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 8
in reply to: TravisNave
Dear Support,
The problem is we are using AutoCAD 2009 LT then when i exported the license using portable utility then imported it to a new computer. The full license has already an expiration date. why is that?
LTU is for AutoCAD 2010 above only.
Message 4 of 8
TravisNave
That is because 2009 and 2010 have expired under Subscription.  The lease on those, with exception, are now good on a year by year basis.  You will have to activate after approximately 13-months or upgrade to the latest version.  This is by design.
Autodesk Forums:
Message 5 of 8
Dear Support,
So when our AutoCAD 2009 LT Full License becomes expired we can still activate it again?
Because the problem is why it will become expired when it is a full license.
Also even 2009 and 2010 have expired under Subscription. We really dont care as long as our license for 2009 LT is a full license.
Are you really sure about your answer?
I cannot understand what is the relevance of 2009 and 2010 have expired under Subscription & our full license has expiry date since before i exported it the full license has no expiry date.
Thank you.
Message 6 of 8
TravisNave
It's my job to be sure. You might be able to get an exception though
depending on your circumstances.
Autodesk Forums:
Message 7 of 8
Dear Support,
What do you mean about "You might be able to get an exception though depending on your circumstances"?
Message 8 of 8
TravisNave
Usually this means that you've never registered a newer version or that
your last registered version under subscription still allows for the 3
previous versions to cover the one you want to activate.
Autodesk Forums:
Administrator Productivity
