Installation & Licensing
Active Contributor
mark.martin.se
Message 1 of 16 (7,854 Views)
Expired License
7854 Views, 15 Replies
10-19-2012 10:25 AM
Hi,....
....just installed ASD 2013 trial version and got "Expired License" -> "The AutoCAD Structural Detailing 2013 license has expired"...Please see the attached picture!
I'm running Windows 7 64x Ultimate.
Any suggestion would be highly appreciated!
Regards!
Product Support
emily.xu
Message 2 of 16 (7,740 Views)
Re: Expired License
10-22-2012 01:24 AM in reply to: mark.martin.se
There are two possible reason for your issue.
1   The ASD was installed with an invalid SN which maybe upgraded, so you should use 2013 SN to install
2   Please try to install Revit Structure if your product is suite.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
New Member
CARLOCHIABRANDO6369
Message 3 of 16 (7,718 Views)
Re: Expired License
10-22-2012 06:49 AM in reply to: mark.martin.se
hi
i have same problem
i try install a trial versiono of ASD 2013 (no have insert SN code), and i find the same message "license exioperd"
i have Revit Structure Suite 2013 (revit struucture + ASD)  with subscription
on the same pc i have ASD 2012 permanent active, when i install ASD 2013 the activation of 2012 version fail ....
I think that the problem is in the control file of the license is corrupt as I do not know how to fix it or replace it
you have an idea to resolve this problem?
thanks
c.c.c.
dieter
Message 4 of 16 (7,624 Views)
Re: Expired License
10-24-2012 01:48 AM in reply to: mark.martin.se
I doesn't make sense to search for a Revit Structure Suite 2013, since this one is only available for customers who have active subscription on Revit Structure Suite 2012. Or am I wrong?
What if a potential user wants a trial of ASD 2013, and is planning to buy Building Design Suite Standard...
We also have the problem when a single ASD 2013 downloaded from the official autodesk.com site, is installed as 30-trial version.
Dieter Vermeulen
Product Manager AEC
i-Theses bvba
Belgium
Product Support
emily.xu
Message 5 of 16 (7,616 Views)
Re: Expired License
10-24-2012 02:26 AM in reply to: CARLOCHIABRANDO6369
You can find here to reset your standalone license.
Emily Xu
New Member
CARLOCHIABRANDO6369
Message 6 of 16 (7,559 Views)
Re: Expired License
10-25-2012 01:07 AM in reply to: mark.martin.se
tanks
but
I had already tried this procedure
the problem is also installing a trial version
Product Support
emily.xu
Message 7 of 16 (7,488 Views)
Re: Expired License
10-26-2012 12:20 AM in reply to: CARLOCHIABRANDO6369
We're so sorry for the inconvenience. But we're working on this issue, will keep you updated when we get the solution. Thank you very much to report this problem and your patience!
Emily Xu
Product Support
emily.xu
Message 8 of 16 (7,355 Views)
Re: Expired License
10-28-2012 07:44 PM in reply to: emily.xu
Currently, the temporary workaround is to change the date of the system back one month or so, launch the product and activate it, close it and change the date to the correct one.
Emily Xu
New Member
ACADChick
Message 9 of 16 (7,285 Views)
Re: Expired License
10-30-2012 06:10 PM in reply to: emily.xu
Not a solution when trying to run the trial. Before I thought it through, I changed the date (and ASD ran), but now my trial is over after running for only 1 day!
Unless there is a way to reset the TRIAL PERIOD... I'm outta luck.
Product Support
emily.xu
Message 10 of 16 (7,242 Views)
Re: Expired License
10-31-2012 07:03 PM in reply to: ACADChick
We're so sorry for the inconvenience for you!
Our developer just released a hotfix for this issue, you can download and install from here.See the readme for the installation instruction.
Be noted, this hotfix applys not only to prospects trying to run the software in trail mode but also to try to input serial number and register the software after installing it in trail mode.
Emily Xu
You are not logged in.
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
