• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Product Support
    Accepted Solution
    Exception in acmgd.dll ARX Command - Unhandled Exception E0434F4D
    5299 Views, 6 Replies
    09-30-2010 07:48 AM
    Using Windows 7 x64 and running AutoCAD 2010/2011, you will get the following error:
    Unhandled Exception E0434F4D(e0434f4dh) at address 7c81EB33h
    Please find the solution in the AutoCAD section:
    http://forums.autodesk.com/t5/AutoCAD-2006/Exception-in-acmgd-dll-ARX-Command/td-p/1599600
    Add "Read" and "Read and Execute" to the local group "Users" for the file:
    "C:\Windows\Microsoft.NET\Framework\v2.0.50727\CONFIG\machine.config"
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
    New Member
    nathan
    Re: Exception in acmgd.dll ARX Command - Unhandled Exception E0434F4D
    09-30-2010 07:51 AM in reply to: david.lau
    To clarify, I had to change the file inside the Framework64 directory, not the Framework directory.
    Path:
    C:\Windows\Microsoft.NET\Framework64\v2.0.50727\CONFIG\machine.config
    New Member
    crossley
    06-15-2011 04:51 AM in reply to: david.lau
    I'm getting the same error on a user's Windows 7 64-bit laptop.  Trying to get support is like having a root canal.  I've had a support case open (06536905) since June 10 & have heard absolutely nothing from Autodesk.  For the price you have to pay for this product, you'd think they'd have a support team.  I've even sent several emails to Product Support, begging for a reply to my case.  The only response I got was priceless: Autodesk has upgraded our CRM system to Salesforce.com. As part of this upgrade, all open and recent Service Requests have been migrated to the new system. To update your issue, log into your online Autodesk portal and select the appropriate Case. All emails to this address will not be read by Autodesk.
    I had to uninstall AutoCAD LT 2012 from the user's laptop and reinstall AutoCAD LT 2008, because (for some strange reason), he needed to complete a drawing.  Now, I have to wait for him to free up his laptop for a couple hours so that I can try again.
    WORST SUPPORT TEAM EVER.
    New Member
    ITGuy2
    07-12-2011 09:42 AM in reply to: crossley
    I also ran into this issue on a Windows 7 64-bit laptop.  The solution is relatively simple if you think about it.
    The original post was from back in 2008 and was referencing the .NET v2.0x folder.  With the 2012 version, it requires .NET 4.0.  So I went in and made the same permissions modification to the same files under the v4.0 folder instead. However, in my case, I was adding "domain users" permissions to the files.  Worked like a charm!
    Product Support
    08-04-2011 08:14 AM in reply to: ITGuy2
    In a recent case, we had to add Users and Everyone full control to this file:
    C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Config\machine.config
    Everything worked as expected.  The target computer was running Windows 7 x64.
    David Lau
    TOOCH
    12-09-2011 01:12 AM in reply to: david.lau
    The target computer in my case is running Windows 7 32-bit.
    Should I change the permissions of this file then?
    C:\Windows\Microsoft.NET\Framework\v4.0.30319\Config\machine.config
    Active Member
    Coupee36
    03-26-2012 08:49 AM in reply to: david.lau
    Hi, I am experiencing the same problem on a 64bit Win7 systems as well.  Though its a simple fix, but does anyone know how to avoid this problem prior to the installation, because my users are setup as domain users and its becoming a pain upgrading 10 workstations and having to change the file permission on each workstation, its just an addiiotonal step that ends up time consuming.
    Thanks.
