Installation & Licensing
Product Support
david.lau
Message 1 of 17 (14,238 Views)
Exception in acmgd.dll ARX Command - Unhandled Exception E0434F4D
14238 Views, 16 Replies
09-30-2010 07:48 AM
Using Windows 7 x64 and running AutoCAD 2010/2011, you will get the following error:
Unhandled Exception E0434F4D(e0434f4dh) at address 7c81EB33h
Please find the solution in the AutoCAD section:
http://forums.autodesk.com/t5/AutoCAD-2006/Exception-in-acmgd-dll-ARX-Command/td-p/1599600
Add "Read" and "Read and Execute" to the local group "Users" for the file:
"C:\Windows\Microsoft.NET\Framework\v2.0.50727\CONFIG\machine.config"
David Lau
New Member
nathan
Message 2 of 17 (14,235 Views)
Re: Exception in acmgd.dll ARX Command - Unhandled Exception E0434F4D
09-30-2010 07:51 AM in reply to: david.lau
To clarify, I had to change the file inside the Framework64 directory, not the Framework directory.
Path:
C:\Windows\Microsoft.NET\Framework64\v2.0.50727\CONFIG\machine.config
New Member
crossley
Message 3 of 17 (11,797 Views)
06-15-2011 04:51 AM in reply to: david.lau
I'm getting the same error on a user's Windows 7 64-bit laptop.  Trying to get support is like having a root canal.  I've had a support case open (06536905) since June 10 & have heard absolutely nothing from Autodesk.  For the price you have to pay for this product, you'd think they'd have a support team.  I've even sent several emails to Product Support, begging for a reply to my case.  The only response I got was priceless: Autodesk has upgraded our CRM system to Salesforce.com. As part of this upgrade, all open and recent Service Requests have been migrated to the new system. To update your issue, log into your online Autodesk portal and select the appropriate Case. All emails to this address will not be read by Autodesk.
I had to uninstall AutoCAD LT 2012 from the user's laptop and reinstall AutoCAD LT 2008, because (for some strange reason), he needed to complete a drawing.  Now, I have to wait for him to free up his laptop for a couple hours so that I can try again.
WORST SUPPORT TEAM EVER.
New Member
ITGuy2
Message 4 of 17 (11,527 Views)
07-12-2011 09:42 AM in reply to: crossley
I also ran into this issue on a Windows 7 64-bit laptop.  The solution is relatively simple if you think about it.
The original post was from back in 2008 and was referencing the .NET v2.0x folder.  With the 2012 version, it requires .NET 4.0.  So I went in and made the same permissions modification to the same files under the v4.0 folder instead. However, in my case, I was adding "domain users" permissions to the files.  Worked like a charm!
Product Support
david.lau
Message 5 of 17 (11,343 Views)
08-04-2011 08:14 AM in reply to: ITGuy2
In a recent case, we had to add Users and Everyone full control to this file:
C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Config\machine.config
Everything worked as expected.  The target computer was running Windows 7 x64.
David Lau
TOOCH
Message 6 of 17 (10,363 Views)
12-09-2011 01:12 AM in reply to: david.lau
The target computer in my case is running Windows 7 32-bit.
Should I change the permissions of this file then?
C:\Windows\Microsoft.NET\Framework\v4.0.30319\Config\machine.config
Active Member
Coupee36
Message 7 of 17 (9,434 Views)
03-26-2012 08:49 AM in reply to: david.lau
Hi, I am experiencing the same problem on a 64bit Win7 systems as well.  Though its a simple fix, but does anyone know how to avoid this problem prior to the installation, because my users are setup as domain users and its becoming a pain upgrading 10 workstations and having to change the file permission on each workstation, its just an addiiotonal step that ends up time consuming.
Thanks.
deltacoolguy
Message 8 of 17 (8,251 Views)
08-30-2012 08:16 PM in reply to: david.lau
Could I get a lay description how do do this?  Thanks.
Windows 7-64
8GB RAM
AutoCAD Civil 3D 2013
Product Support
david.lau
Message 9 of 17 (8,239 Views)
08-31-2012 05:52 AM in reply to: david.lau
deltacoolguy
Message 10 of 17 (8,116 Views)
09-16-2012 07:15 PM in reply to: david.lau
I wasn't sure *where* or *how* to make these changes/additions, but I think I figured that part out.  Right-click on these files listed and pick 'properties', correct?
Ok, so I did that, and it appears that "read" and "read & execute" are already seleted for all options.  My user name is also the primary administrator, and that one has "full control".  When I tried to change my user to add "full control" I get an error message and it will not allow me to make the change.
I even looked under 'properties' for C'/USERS, and those appear to have the same settings.
What am I missing?
Windows 7-64
8GB RAM
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
