Installation & Licensing
Errors During Wks Installation
2 REPLIES 2
275 Views, 2 Replies
I have a current single network license server that was running and had a deployment created. Also all wks had the app installed.
This server needs to be removed, so I did a new installation on another server, same network, I did uninstall first the app on  each wks from add and remove programs and then run the install on the new server, install the license manager, request a new license file and create the new deployment. I removed the old server license service and shut down the service. License server on the new server is running fine and the deployment was created successfully, but when I go to any wks and navigate thru the deployment path and execute, I get the installation wizard that it shows the license type, product information, the server name etc, then when I click next  it give me an error that say :
“ ERROR 1324  the folder path program files contains an invalid character “
After I click OK on the message comes another one:
“ Fatal Error During Installation # 205 failed to run AdskExecuteSequence”
Does anyone have any clue why this is happening ? or how can i fix it and complete each wks install correctly.
Thanks in advance.
2 REPLIES 2
emily.xu
TravisNave
It is not necessary to reinstall the workstation if your NLM sever was moved.  You simply need to point the applications already installed to the new NLM server.  You can use a system variable named ADSKFLEX_LICENSE_FILE with a value of @servername where you put the name of your new server.
Check your deployment path creation for invalid paths.  Make sure you are using UNC paths for the deployment location and default locations for the client.  Make sure you are not using roaming profiles or moving system folders like My Documents to a server location.  If all else fails, install from your physical media.
Here is some more information:
http://support.microsoft.com/default.aspx?scid=kb;EN-US;292582
Autodesk Forums:
Administrator Productivity
