I have a current single network license server that was running and had a deployment created. Also all wks had the app installed and were runing ok. this had been the license sever for years for 07,08.10and 12 versions.
This server have to be removed, to do so I did a new installation on another server, same network, I first did uninstall the app on each wks from add and remove programs. then run the install on the new server, install the license manager, request a new license file and install, and create and save the new deployment.
I removed the old server license service and shut down the service. License server on the new server is running fine and the deployment was created successfully, but when I go to any wks to do the reinstallation from the new server and deployement, navigate thru the deployment path, execute the shortcut , installation wizard appears and shows license agreement, the license type, product information, the server name etc, then when I click next it give me the following errors:
“ ERROR 1324 the folder path program files contains an invalid character “
After I click OK on this error, got another:
“ Fatal Error During Installation # 205 failed to run AdskExecuteSequence”
anynone please HELP i need to resolve this ASAP since there is people waiting to use the app and finish important tasks.
Thanks.
For migrating the license server there is an easier method than reinstalling
please check this
http://upandready.typepad.com/up_and_ready/2011/05/migrating-license-server-to-another-machine.html
For the install Error.
Please make sure the sharename for the deployment doesn't have any special character e.g:-$ sign.
try to use another share location with full permission for the user installing it.
Try shorten the path to the deployment.
