Installation & Licensing
Error while trying to install for the second time
1 REPLY 1
liortrau
375 Views, 1 Reply
I installed Maya for the first time and had problems inside the software. I uninstalled hoping that re-installing will fix the problems and it gives me an error.
I attached the log file.
will apriciate your help
Leo
1 REPLY 1
TravisNave
in reply to: liortrau
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
Install	Microsoft Visual C++ 2008 SP1 Redistributable (x64)	Failed	Download Failed, Installation aborted, Result=1603
 If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
The prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
