Hi All;
I recently resolved an issue for another customer and thought I would pass the information here just in case anyone else ran into the same or similiar issue. The full error message is
Error while loading shared libraries: /usr/autodesk/maya2011-x64/lib/libMgMdfModel.so : cannot restore segment prot after reloc: Permission denied.
We found that the SELinux was effecting the library and causing the error. Once SE linux was disable the lbrary files were detected/working fine. Thought the message was a bit mis-leading considering how Linux likes to throw up dependancy errors.
The Qual lists a proper explanation
http://download.autodesk.com/us/qualcharts/2011/maya2011_qualifiedgraphics_lin.pdf
dwayne
Dwayne Poot
Support Specialist
Product Support
