• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    Error when starting Maya 2013
    990 Views, 5 Replies
    10-12-2012 12:52 PM
    Hey, i downloaded the students version of Maya 2013, when i try to run it, a windows error appears (0xc000007b). I am using Windows 7 64bit and mit graphics card is a nvidia GTX 560 TI.
    I hope you can help me.
    - Dominik
    Please use plain text.
    TravisNave
    Re: Error when starting Maya 2013
    10-12-2012 01:46 PM in reply to: dominik.scholz
    Make sure you are running a WHQL certified driver from nvidia.com and then check out this link:
    http://community.softimage.com/forum/autodesk-3ds-max/autodesk-3ds-max--3ds-max-design-2011/max-2011...
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    philip.s
    10-12-2012 01:56 PM in reply to: dominik.scholz
    Hi Dominik,
    Have you tried the suggestions mentioned in the following forum posts?
    The application was unable to start correctly (0xc000007b) - LINK 1
    The application was unable to start correctly (0xc000007b) - LINK 2
    Additionally, your graphics card isn't on the Certified Hardware list for Maya 2013 and as such may be the culprit.
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    New Member
    10-12-2012 02:22 PM in reply to: dominik.scholz
    thanks, but i tried out all the links, no one helped... :smileysad:
    philip.s
    10-12-2012 03:18 PM in reply to: dominik.scholz
    Shucks! As mentioned earlier, it could very well be the graphics card...
    Philip Schmelzer
    TW | PI | YT | BLOG
    New Member
    11-05-2012 03:39 PM in reply to: dominik.scholz
    I have been using the student version for three (3) months and now all of a sudden I am getting this message: Application unable to start correctly (oxc000007b) click ok to close the application.  Why now if it's my graphics card?
