Installation & Licensing
Error when attempting to install Inventor 2012 on Win 7 64-bit
2 REPLIES 2
689 Views, 2 Replies
After I select what components to install, the progress screen skips over everything but the c++ 2010 package (which is the last one to be installed). The installation then fails completely, and I'm not getting an error code. Any ideas?
2 REPLIES 2
TravisNave
The error code will be in your installation log file located in your %TEMP% folder.  If the failure is on the prerequisite install, consider downloading and installing it directly from Microsoft and then trying again.  Make sure you have admin rights, UAC is off, and anti-virus is disabled.  Good luck!
Autodesk Forums:
in reply to: TravisNave
Okay, for some reason I had to uninstall (and then reinstall) a previous installation of c++ 2010. It works now, thanks.
Administrator Productivity
