I had the same problem but managed to fix it.
Try to do the following:
1. Insert the AutoCAD DVD you installed the program from;
2. Go to the Deployment wizard;
3. When selecting Autodesk Installer (MSI) file point out to the DVD not the msi file in your computer. The file should be in the folder Bin/acadFeui.
Good luck,
SL
