Installation & Licensing
Error starting Inventor after a network license has been borrowed.
7 REPLIES 7
Message 1 of 8
scotta
977 Views, 7 Replies
We have an engineer that is overseas and Inventor is giving him problems.  Before he left the country, he borrowed a license to use Inventor.  He says he made sure that it worked before he left and the borrowed license worked.  Now he gets the following error message : "Your application was not able to obtain a license because the FLEXnet license server manager could not determine where to find the licesnsing data it needs.  Please choose one of the following:"  " Specify the License Server System" or " Specify the License File".  I checked LMTools and it says that he is still using a license.   Has anyone else had this problem and know how to correct it?
Scott
7 REPLIES 7
Message 2 of 8
TravisNave
in reply to: scotta
This issue often exists with laptops for a couple of reasons.  The most common is if the laptop has a docking station.  When docked, the laptop has a different hardware ethernet MAC address.  The borrowed license is attached to this connection.  When undocked, the hardware address is changed to the internal NIC and thus the license becomes invalid.  This also happens if the user borrows while on the LAN NIC and then disables and goes WiFi (or vice versa.)  In rare cases, like my laptop for example, my NLM is tied to the BlueTooth device.  So when it is disabled, my licenses are invalid.  In addition, the borrowed license is also attached to the user account.  So even in events where the license is tied to the correct NIC, the user may login as a domain user while on the LAN and then login as a local account while offline. This can cause the same problematic result.  To solve the problem, you need to determine what changes with the laptop when the user borrows the license and then leaves the network.  Your solution will exist there.
Autodesk Forums:
Message 3 of 8
scotta
in reply to: TravisNave
Travis,
The computer in question was connecting to our network with the built in wireless card when he borrowed the license.  It is also setup to automatically log him into his user acount so that shouldn't have changed.  Just to verify what you are saying.......If the wireless card is not active, he will get this error.  Is that correct.  The computer he is using is a Dell M6300 and I'm not sure if he has bluetooth on it or not.  I'll tell him to make sure that both are active and we'll see if that helps.  He's 12 or 13 hours ahead of us so I won't find out if it works until tomorrow.
Message 4 of 8
TravisNave
in reply to: scotta
Correct.  The borrowed license is tied to a hardware MAC address.  Whichever one it chooses to associate with when the borrowing occurs (and sometimes it isn't even the active NIC) will need to be active to ensure that the license can be used.
Autodesk Forums:
Message 5 of 8
fëanor
I seem to have encountered the same exact issue.  I want to confirm that I'm not missing something here; I now have no possible way to get my offline user a license until he is able to reconnect to the license server.  Correct?
If you are correct about the port replicator MAC address being the cause, this sounds like a huge flaw in FlexNET's license borrowing schema.  The MAC address is a poor choice to use as a UID when the point of borrowing a license is to remove the network as a factor.  The fact that it seems to select a random adapter is even more ridiculous.
Now that we know, I will advise my users to always disconnect from the port replicator and connect an Ethernet cable directly to their laptop before borrowing a license.    That sounds like a PITA for them, but hopefully it helps.
Have I mentioned that Autodesk network licensing is killing me this week? Smiley Frustrated
Message 6 of 8
TravisNave
in reply to: fëanor
You are correct in stating that there is no way to get an offline user a borrowed license.  Your only possible work-around would be to registry fix it back to stand-alone and see if it will run as a 30 day trial.  Not much luck doing this though since 2010 was released.
As for the licensing, it's not really Autodesk's fault since they use a 3rd party licensing program.
Autodesk Forums:
Message 7 of 8
fëanor
Thank you for confirming. I'm just making sure I leave no stone unturned.
I suppose we will have to agree to disagree about it being Autodesk's fault...I know I'm not the one who selected Flexera as their partner so it certainly isn't my fault. I checked with the guy next to me and he didn't make that decision either so I am still leaning towards Autodesk as the culprit 😛
Anyway thanks again for the explanation!
Message 8 of 8
TravisNave
in reply to: fëanor
Well said.
Autodesk Forums:
Administrator Productivity
