Installation & Licensing
Error opening 3ds max on Windows8
9 REPLIES 9
Message 1 of 10
784 Views, 9 Replies
Hello everyone, I've made a post here few weeks ago saying that my 3ds Max wasn't opening. Suddenly, the problem was gone and I was able to use it again. Then, last week, it stoped working again, with no aparent reasons. So I tried to install the 2013 version (I was using the 2014). It worked for a while, but now it's giving the same problem. I really need to use it for my classes, and I can't find a solution.
I have an Asus N46V
Windows 8 64bits
Nvidia Geforce GT 630M 2GB
Thanks in advance!
9 REPLIES 9
Message 2 of 10
TravisNave
Start by doing a clean install of this driver:
http://www.nvidia.com/object/notebook-win8-win7-64bit-320.49-whql-driver.html
Autodesk Forums:
Message 3 of 10
in reply to: TravisNave
Should I restart my computer afterwards? I tried opening the program, but it didn't work.
Message 4 of 10
TravisNave
Yes.  Installing the driver clean (did you check that box?) should require a restart.
Autodesk Forums:
Message 5 of 10
sorry, I haven't checked the box. But I did now, and i've already restart my computer. But 3ds max isn't working 😕
Message 6 of 10
TravisNave
Is it the activation crash, by chance?
Autodesk Forums:
Message 7 of 10
I don't think so. I've reinstalled it several times, and I was able to activate it. Then the problem was gone without doing anything, and it's back again. It's really weird
Message 8 of 10
TravisNave
Again, my only recommendation then would be to try a system restore back to a point in time that you knew it was working.  Possibly some Windows Update or another installed program has caused this issue...
Autodesk Forums:
Message 9 of 10
Any other sugestions? I don't think it would work for me... Actually, I don't even know exactly how to restore.
Message 10 of 10
TravisNave
System Restore is quick and it is reversible if it does not work.
Here are the instructions:
http://windows.microsoft.com/en-us/windows-8/restore-refresh-reset-pc
Good Luck!
Autodesk Forums:
Administrator Productivity
