The System Requirements, http://images.autodesk.com/adsk/files/DWG_TrueView_2012_System_Requirements.pdf, state TrueView only works on XP, Vista and W7
I wanted to install TrueView on a W2003 R2 Server but had a similar error message 😞
I'm getting the same issue, with the same message. I'm installing to my laptop, which is running Windows 7, so the operating system is not the problem. I do have internet to this system, so that's not the problem. Anybody know what is happening with this?
Hi there,
I am stuck with the same error message while installing TrueView 2012 on a laptop running Win7 Pro (x64) + SP1.
.Net FWK is up to date.
Does any body has a solution ?
Best regards,
Pierre
I am getting the same message. I am on 2007 Windows XP. I have Autocad LT 2007 and am trying to open files created in a new version of Autocad. Any suggestions?
Please try
->Uninstall any old version of Design Review or Trueview you have.
->Delete %temp% folder content (to get to %temp folder, start->run/search->type %temp% ->Enter)
If it doesn't help
please try to install the software in diagnostics mode as described here
http://usa.autodesk.com/getdoc/id=TS75218
If the issue persists, please post the all the log files from the %temp% folder (start->run/search->type %temp% ->Enter) as a zip file.
If it is on Windows 2008 server please make sure TRANSFORMSSECURE is set to 0
http://upandready.typepad.com/up_and_ready/2012/02/installation-unable-to-create-a-temp-copy-of-tran...
Tried everything and more. No success. Zip file attached.
I zipped what showed up in my temp file. Attached it. Got an alert, "The attachment file size is too large. The Maxim...".
Now I will just send the log file.
Debugging through an internal case, will post the outcome here.
