Hi , I have installed LDDT3 on win 7 and it went on smooth, but when i try to run the program , an error occur : error loading cdilla dll. Does this mean that my installation is uncuccessful or there is compitablitiy issue with win 7.. my computer is 32 bit . Previously I used WinXP with the old computer ( no longer use) to run LDDT3. Could it be that this migration from a computer to another computer is unauthoried therefore the it didn't run.
Solved by TravisNave. Go to Solution.
I can almost certainly guaratee that the cdilla licensing scheme is not compatible with Windows 7. Your program is not supported on Windows 7. You can continue to run it on Windows XP, but you will not get any kind of support. But hey, if it works, it works.
