Installation & Licensing
*Hänninen, Juha
Message 1 of 4 (96 Views)
Error loading arx with Acad2002
96 Views, 3 Replies
10-24-2001 05:07 PM
While trying to get everything to work with AutoCAD 2002 and Windows 2000 I
got an strange error message while trying to load an arx from Netware server
Command: arx
Enter an option [?/Load/Unload/Commands/Options]: l
Error code (0x20) The process cannot access the file because it is being
used
by another process.
AcRxDynamicLinker failed to load 'M:\ACAD\PID\WHOHAS.ARX'
C:\Program Files\AutoCAD 2002\acad.exe
Command
With AutoCAD R14 everything works. Is 2002 not supported in Windows 2000
client / Netware environment?
I´m using Microsoft client for Netware. The same happens with every arx I
try to open from the network. Opening from local disk works.
Is there anybody else having the same problem?
Juha Hanninen
*martin, jason
Message 2 of 4 (96 Views)
Re: Error loading arx with Acad2002
10-24-2001 11:15 PM in reply to: *Hänninen, Juha
Juha -
I don't know if this will help but have you tried marking the file as shareable in netware???
jason martin
frankfurt-short-bruza
"Juha Hänninen" wrote in message news:813BBE069B82731A0AA1B0E7DC2B6481@in.WebX.maYIadrTaRb...
> Hi,
> Command: arx
> used
> by another process.
> Command
> Regards,
> Juha Hanninen
*Hänninen, Juha
Message 3 of 4 (96 Views)
Re:
10-25-2001 03:05 PM in reply to: *Hänninen, Juha
Yes, I tried that, but it didn't help.
The strange thing is that everything works with R14! Autodesk seems to have
changed the way AutoCAD opens files.
Juha
"jason martin" wrote in message
news:smileyvery-happy:736CE5250BE554CB782A3926D231BCC@in.WebX.maYIadrTaRb...
> Juha -
> jason martin
> > Hi,
2000 I
server
> > Command: arx
> > used
> > by another process.
> > Command
I
> > Regards,
> > Juha Hanninen
New Member
crp0826
Message 4 of 4 (96 Views)
12-10-2002 05:10 AM in reply to: *Hänninen, Juha
Did you ever find an answer to your trouble with loading ARX files?
We're experiencing a similar problem.
We've moved files to a W2K server and removed Novell's Client32.
We see the following error:
AcRxDynamicLinker failed to load - ACADSTAR.ARX
Trying to load it manaully doesn't work.
Trying to load it from the original Netware server does NOT work (yes, it's flagged shareable)
Any ideas appreciated.
Please respond via email too as I don't frequent these news groups. (I'm just desperate for a solution ;-) Thanks.
- Daryl -
Daryl Sawders
sawders@ppg.com
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
