Installation & Licensing
Error launch Inventor Professional 2014
1 REPLY 1
denesecouch
1603 Views, 1 Reply
I downloaded Inventor Professional 2014 and when I tried to install it I got an error message stating that the download contains several files and one or more is missing. I selected to close that window and it closes everything in the installer and I am unable to download and install. I have an HP computer with Windows 8.
I have downloaded, installed,  and am using Autodesk AutoCAD 2014 and Revit 2014 without any problems. Also, I used the browser method of downloading because I assumed it is the same as downloading the other products and that is the method I had to use with them because it is the only method that works with Windows 8. Please can you help me?
Computer Specs:
Intel Pentium CPU 2020M @ 2.40GHz 2.40 GHz
64-bit Operating System, x64-based processor
1 REPLY 1
TravisNave
in reply to: denesecouch
Welcome to the community.
Try downloading it from the virtual assistant.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Good Luck!
Autodesk Forums:
Administrator Productivity
