• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Error installint Inventor 2012
    347 Views, 8 Replies
    09-13-2011 12:54 PM
    Hello - I have a user who is getting a very strange error message during the initialization process, see attached JPGs.  We have replaced the dll with one from an setup that we know works, I have had him delete the .pit file from the machine he's trying to install the program on, does not work.  He's never had Inventor 2012 installed on this machine.  64 bit installation on Windows 7.
    thanks,
    Tracy Davis
    Employee
    Re: Error installint Inventor 2012
    09-13-2011 06:47 PM in reply to: tracydavis
    Could you please try to copy the insallation package of Inventor to the local machine and install from it directly to see whether still have this problem?
    Helen
    09-14-2011 08:48 AM in reply to: HelenChen-Autodesk
    Sorry, I forgot to put in the original message that we did try to copy the installation locally.  I also had the user download from a known good copy of Inventor and it did not work either.
    Tracy
    Employee
    09-14-2011 06:17 PM in reply to: tracydavis
    Are you using Education version of Inventor 2012? The installation package is downloaded from network or you have DVD of Inventor 2012 installer? Did you try to launch the setup.exe in other machines with from same installer source to see whether see the same problem?
    And could you please check out whether the file version and the size of adlmPIT.dll in the installer?
    My version is: 4.0.35.0
    Size is: 1.28 MB (1,348,008 bytes)
    Helen
    09-15-2011 07:39 AM in reply to: HelenChen-Autodesk
    Thanks Helen for the response.  It is education version and we have tried DVD and downloaded versions.  I have also had the user download the software from subscription center along with my companies FTP site, same result.  He was successful with installing the software on another machine, so it's something on this particular machine that is causing the issue, which is his master machine and has quite a bit of Autodesk software on it already and he doesn't want to have to uninstall everything if completely possible.
    Active Member
    02-08-2012 04:27 AM in reply to: tracydavis
    Tracy,
    Did you solved the problem? I have the same issue. I'm trying to install the product design suite on a citrix vm, and I get the same messages. I need this for a test-environment for a PDM-system.
    Nico Blok
    02-08-2012 01:42 PM in reply to: nico
    Nico,
    To be honest, I don't remember what the solution was.  I've looked back through emails and cases around that time and can't seem to locate this one.  Sorry.
    ***Guru
    TravisNave
    02-08-2012 02:08 PM in reply to: nico
    Keep in mind that not all Autodesk products are supported in the Citrix environment and requires special licensing to remain compliant with the EULA.
    http://forums.autodesk.com/t5/Installation-Licensing/Autodesk-EULA-and-non-Citrix-Virtualization/td-...
    My Top Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files | Search Autodesk Discussion Groups
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    02-12-2012 11:40 PM in reply to: tracydavis
    I fixed the issue. I have made a installation image with a fysical workstation. I used that image to install on the Citrix machine.
    About the license: This is a dedicated VM which will run for a maybe a week or two, to test a new version of the PDM system.
