Installation & Licensing
Error installing BDSU 2014 from web
2 REPLIES 2
corey_schiller
2633 Views, 2 Replies
I donwloaded the Building Design Suite Ultimate 2014 update from autodesk subscription center using the Autodesk download manager which gave me (5) files:
Building_Design_Suite_Ultimate_2014_English_Win_32_64bit_dlm_001_005.sfx
Building_Design_Suite_Ultimate_2014_English_Win_32_64bit_dlm_002_005.sfx
Building_Design_Suite_Ultimate_2014_English_Win_32_64bit_dlm_003_005.sfx
Building_Design_Suite_Ultimate_2014_English_Win_32_64bit_dlm_004_005.sfx
Building_Design_Suite_Ultimate_2014_English_Win_32_64bit_dlm_005_005.sfx
I extracted them and launched the "Setup.exe" file in the newly created "Building_Design_Suite_Ultimate_2014_English_Win_32_64bit_dlm" directory.  The installer starts and says initializing but then an error window opens saying "The system cannot open the device of file specified. C:\Users\CSCHIL~1\AppData\Local\Temp\_AIB367.tmp\x64\NAVMAN\roamer.msi"
I've gone to this directory and confirmed the roamer.msi file does exist here.  I've tried clearing the Temp directory and re-extracting the installer from the downloaded files with the same result.
Possibly worth noting, I downloaded the web files to my 😧 drive, and extracted them to the C: drive (SSD) for installing, if that makes any difference.
2 REPLIES 2
TravisNave
in reply to: corey_schiller
Clear your %TEMP% folder and make sure you are installing with local admin rights, UAC off, and especially your anti-virus turned off.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
corey_schiller
in reply to: TravisNave
Thanks, it was the anti-virus!
Administrator Productivity
