I have 3ds MAX Design 2012 installed and working, when i try to install the Subscription Advantage Pack I recieve a dialog box saying there has been a unhandeled exception error.
I have attached the Error.
Any Ideas?
This is the install i'm trying to use maxdes_2012_ap_201109_winall_001_enu.exe
Windows 7 x64
x64 version of 3ds Max Design 2012 (Without SP2)
Thanks.
I’m curious about your video card and video driver version.
Unhandled exception errors you received during 3ds Max Design 2012 SAP install could be caused by corrupted video card drivers. Could you please check your video card in Autodesk Certified Graphics Hardware list and if it is listed there, please download (reinstall) the certified drivers.
The Certified Hardware list is located here: http://usa.autodesk.com/adsk/servlet/cert?siteID=123112&id=
Please let us know if this resolves the issue.
The Certified Hardware list is located here: http://usa.autodesk.com/adsk/servlet/cert?siteID=123112&id=16391880
I was able to install the .msi file in the Temp directory for the SAP so for now i'm set, this only happened on 1 machine so far so I hope its this machine only.
Thanks for the input.
Thanks for the update.
I'm glad to hear that the issue is resolved.
