Hi, I have this problem:
2011/7/23:22:22:47Rafael CabralSONY-210E=== Setup started on SONY-210E by Rafael Cabral ===2011/7/23:22:22:47Rafael CabralSONY-210ELaunch 2011/7/23:22:23:18Rafael CabralSONY-210E=== Setup ended ===
2011/7/23:22:22:48Rafael CabralSONY-210E=== Setup started on SONY-210E by Rafael Cabral ===2011/7/23:22:22:48Rafael CabralSONY-210ELaunch 2011/7/23:22:23:19Rafael CabralSONY-210EPageOpenLaunchDialog2011/7/23:22:23:38Rafael CabralSONY-210EYour computer is using an unsupported version of the Microsoft .NET Framework. The product you are installing requires Microsoft .NET Framework 4.0 or later.
Please update .NET Framework 4.0 and restart your computer before installing your Autodesk product.2011/7/23:22:23:48Rafael CabralSONY-210E=== Setup ended ===
2011/7/23:22:33:18Rafael CabralSONY-210E=== Setup started on SONY-210E by Rafael Cabral ===2011/7/23:22:33:18Rafael CabralSONY-210ELaunch 2011/7/23:22:36:39Rafael CabralSONY-210E=== Setup ended ===
2011/7/23:22:33:19Rafael CabralSONY-210E=== Setup started on SONY-210E by Rafael Cabral ===2011/7/23:22:33:19Rafael CabralSONY-210ELaunch 2011/7/23:22:36:42Rafael CabralSONY-210EPageOpenLaunchDialog2011/7/23:22:37:18Rafael CabralSONY-210EPageOpenLicenseDialog2011/7/23:22:37:24Rafael CabralSONY-210EPageOpenProductInfoDialog2011/7/23:22:38:22Rafael CabralSONY-210EPageOpenProductSelectionDialog22011/7/23:22:39:11Rafael CabralSONY-210EPageOpenFullProgressDialog2011/7/23:22:39:11Rafael CabralSONY-210EInstalling .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe /q2011/7/23:22:40:46Rafael CabralSONY-210EInstall.NET Framework Runtime 4.0 Language PackSucceeded2011/7/23:22:40:46Rafael CabralSONY-210EInstalling Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q2011/7/23:22:40:51Rafael CabralSONY-210EInstallMicrosoft Visual C++ 2008 SP1 Redistributable (x86)Succeeded2011/7/23:22:40:51Rafael CabralSONY-210EInstalling Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q2011/7/23:22:41:01Rafael CabralSONY-210EInstallMicrosoft Visual C++ 2008 SP1 Redistributable (x64)Succeeded2011/7/23:22:41:01Rafael CabralSONY-210EInstalling DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent2011/7/23:22:41:47Rafael CabralSONY-210EInstallDirectX RuntimeSucceeded2011/7/23:22:41:47Rafael CabralSONY-210EInstalling FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/7/23:22:42:17Rafael CabralSONY-210EInstallFaroSDKSucceeded2011/7/23:22:42:17Rafael CabralSONY-210EInstalling Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/7/23:22:42:45Rafael CabralSONY-210EInstallAutodesk Material Library 2012Succeeded2011/7/23:22:42:45Rafael CabralSONY-210EInstalling Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/7/23:22:43:24Rafael CabralSONY-210EInstallAutodesk Material Library 2012 - Low ResolutionSucceeded2011/7/23:22:43:24Rafael CabralSONY-210EInstalling Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\RAFAEL~1\AppData\Local\Temp\vcredist_x86_2005.log"" "2011/7/23:22:43:26Rafael CabralSONY-210EInstallMicrosoft Visual C++ 2005 Redistributable (x86)FailedInstallation aborted, Result=16032011/7/23:22:43:52Rafael CabralSONY-210ERollbackAutodesk Material Library 2012 - Low ResolutionSucceeded2011/7/23:22:44:23Rafael CabralSONY-210ERollbackAutodesk Material Library 2012Succeeded2011/7/23:22:44:26Rafael CabralSONY-210ERollbackFaroSDKSucceeded2011/7/23:22:44:26Rafael CabralSONY-210ERollbackDirectX RuntimeFailedFailure is ignored, Result=16192011/7/23:22:44:27Rafael CabralSONY-210ERollback.NET Framework Runtime 4.0 Language PackFailedInstallation aborted, Result=16192011/7/23:22:44:27Rafael CabralSONY-210EPageOpenInstallCompleteDialog2011/7/23:22:46:20Rafael CabralSONY-210E=== Setup ended ===
2011/7/23:23:21:44Rafael CabralSONY-210E=== Setup started on SONY-210E by Rafael Cabral ===2011/7/23:23:21:44Rafael CabralSONY-210ELaunch 2011/7/23:23:23:10Rafael CabralSONY-210E=== Setup ended ===
2011/7/23:23:21:45Rafael CabralSONY-210E=== Setup started on SONY-210E by Rafael Cabral ===2011/7/23:23:21:45Rafael CabralSONY-210ELaunch 2011/7/23:23:23:12Rafael CabralSONY-210EPageOpenLaunchDialog2011/7/23:23:23:27Rafael CabralSONY-210EPageOpenLicenseDialog2011/7/23:23:24:15Rafael CabralSONY-210EPageOpenProductInfoDialog2011/7/23:23:24:48Rafael CabralSONY-210EPageOpenProductSelectionDialog22011/7/23:23:25:28Rafael CabralSONY-210EPageOpenFullProgressDialog2011/7/23:23:25:29Rafael CabralSONY-210EInstalling .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe /q2011/7/23:23:27:20Rafael CabralSONY-210EInstall.NET Framework Runtime 4.0 Language PackSucceeded2011/7/23:23:27:20Rafael CabralSONY-210EInstalling DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent2011/7/23:23:28:13Rafael CabralSONY-210EInstallDirectX RuntimeSucceeded2011/7/23:23:28:13Rafael CabralSONY-210EInstalling FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/7/23:23:28:42Rafael CabralSONY-210EInstallFaroSDKSucceeded2011/7/23:23:28:42Rafael CabralSONY-210EInstalling Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/7/23:23:29:12Rafael CabralSONY-210EInstallAutodesk Material Library 2012Succeeded2011/7/23:23:29:12Rafael CabralSONY-210EInstalling Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/7/23:23:29:50Rafael CabralSONY-210EInstallAutodesk Material Library 2012 - Low ResolutionSucceeded2011/7/23:23:29:50Rafael CabralSONY-210EInstalling Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\RAFAEL~1\AppData\Local\Temp\vcredist_x86_2005.log"" "2011/7/23:23:29:51Rafael CabralSONY-210EInstallMicrosoft Visual C++ 2005 Redistributable (x86)FailedInstallation aborted, Result=16032011/7/23:23:30:15Rafael CabralSONY-210ERollbackAutodesk Material Library 2012 - Low ResolutionSucceeded2011/7/23:23:30:44Rafael CabralSONY-210ERollbackAutodesk Material Library 2012Succeeded2011/7/23:23:30:46Rafael CabralSONY-210ERollbackFaroSDKSucceeded2011/7/23:23:30:47Rafael CabralSONY-210ERollbackDirectX RuntimeFailedFailure is ignored, Result=16192011/7/23:23:30:47Rafael CabralSONY-210ERollback.NET Framework Runtime 4.0 Language PackFailedInstallation aborted, Result=16192011/7/23:23:30:47Rafael CabralSONY-210EPageOpenInstallCompleteDialog2011/7/23:23:31:21Rafael CabralSONY-210E=== Setup ended ===
2011/7/24:00:39:23Rafael CabralSONY-210E=== Setup started on SONY-210E by Rafael Cabral ===2011/7/24:00:39:23Rafael CabralSONY-210ELaunch 2011/7/24:00:40:23Rafael CabralSONY-210E=== Setup ended ===
2011/7/24:00:39:24Rafael CabralSONY-210E=== Setup started on SONY-210E by Rafael Cabral ===2011/7/24:00:39:24Rafael CabralSONY-210ELaunch 2011/7/24:00:40:23Rafael CabralSONY-210EPageOpenLaunchDialog2011/7/24:00:41:21Rafael CabralSONY-210EPageOpenLicenseDialog2011/7/24:00:41:33Rafael CabralSONY-210EPageOpenProductInfoDialog2011/7/24:00:42:00Rafael CabralSONY-210EPageOpenProductSelectionDialog22011/7/24:00:43:02Rafael CabralSONY-210EPageOpenFullProgressDialog2011/7/24:00:43:02Rafael CabralSONY-210EInstalling .NET Framework Runtime 4.0 Language Pack: F:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe /q2011/7/24:00:45:10Rafael CabralSONY-210EInstall.NET Framework Runtime 4.0 Language PackSucceeded2011/7/24:00:45:10Rafael CabralSONY-210EInstalling DirectX Runtime: F:\3rdParty\DirectX\DXSETUP.exe /silent2011/7/24:00:46:05Rafael CabralSONY-210EInstallDirectX RuntimeSucceeded2011/7/24:00:46:05Rafael CabralSONY-210EInstalling FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/7/24:00:46:34Rafael CabralSONY-210EInstallFaroSDKSucceeded2011/7/24:00:46:35Rafael CabralSONY-210EInstalling Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\RAFAEL~1\AppData\Local\Temp\_AI4D84.tmp\Media.mst"
2011/7/24:00:47:11Rafael CabralSONY-210EInstallAutodesk Material Library 2012Succeeded2011/7/24:00:47:14Rafael CabralSONY-210EInstalling Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\RAFAEL~1\AppData\Local\Temp\_AI4D84.tmp\Media.mst"
2011/7/24:00:47:59Rafael CabralSONY-210EInstallAutodesk Material Library 2012 - Low ResolutionSucceeded2011/7/24:00:47:59Rafael CabralSONY-210EInstalling Microsoft Visual C++ 2005 Redistributable (x86): F:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\RAFAEL~1\AppData\Local\Temp\vcredist_x86_2005.log"" "2011/7/24:00:48:04Rafael CabralSONY-210EInstallMicrosoft Visual C++ 2005 Redistributable (x86)FailedInstallation aborted, Result=16032011/7/24:00:48:44Rafael CabralSONY-210ERollbackAutodesk Material Library 2012 - Low ResolutionSucceeded2011/7/24:00:49:17Rafael CabralSONY-210ERollbackAutodesk Material Library 2012Succeeded2011/7/24:00:49:22Rafael CabralSONY-210ERollbackFaroSDKSucceeded2011/7/24:00:49:22Rafael CabralSONY-210ERollbackDirectX RuntimeFailedFailure is ignored, Result=16192011/7/24:00:49:22Rafael CabralSONY-210ERollback.NET Framework Runtime 4.0 Language PackFailedInstallation aborted, Result=16192011/7/24:00:49:23Rafael CabralSONY-210EPageOpenInstallCompleteDialog2011/7/24:00:49:47Rafael CabralSONY-210E=== Setup ended ===
2011/7/24:00:57:12Rafael CabralSONY-210E=== Setup started on SONY-210E by Rafael Cabral ===2011/7/24:00:57:12Rafael CabralSONY-210ELaunch 2011/7/24:00:57:28Rafael CabralSONY-210E=== Setup ended ===
2011/7/24:00:57:13Rafael CabralSONY-210E=== Setup started on SONY-210E by Rafael Cabral ===2011/7/24:00:57:13Rafael CabralSONY-210ELaunch 2011/7/24:00:57:28Rafael CabralSONY-210EPageOpenLaunchDialog2011/7/24:00:58:21Rafael CabralSONY-210EPageOpenLicenseDialog2011/7/24:00:58:28Rafael CabralSONY-210EPageOpenProductInfoDialog2011/7/24:00:58:43Rafael CabralSONY-210EPageOpenProductSelectionDialog22011/7/24:00:59:31Rafael CabralSONY-210EPageOpenFullProgressDialog2011/7/24:00:59:31Rafael CabralSONY-210EInstalling .NET Framework Runtime 4.0 Language Pack: F:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe /q2011/7/24:01:01:14Rafael CabralSONY-210EInstall.NET Framework Runtime 4.0 Language PackSucceeded2011/7/24:01:01:14Rafael CabralSONY-210EInstalling DirectX Runtime: F:\3rdParty\DirectX\DXSETUP.exe /silent2011/7/24:01:01:53Rafael CabralSONY-210EInstallDirectX RuntimeSucceeded2011/7/24:01:01:53Rafael CabralSONY-210EInstalling FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/7/24:01:02:20Rafael CabralSONY-210EInstallFaroSDKSucceeded2011/7/24:01:02:22Rafael CabralSONY-210EInstalling Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\RAFAEL~1\AppData\Local\Temp\_AI9D59.tmp\Media.mst"
2011/7/24:01:02:47Rafael CabralSONY-210EInstallAutodesk Material Library 2012Succeeded2011/7/24:01:02:49Rafael CabralSONY-210EInstalling Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\RAFAEL~1\AppData\Local\Temp\_AI9D59.tmp\Media.mst"
2011/7/24:01:03:26Rafael CabralSONY-210EInstallAutodesk Material Library 2012 - Low ResolutionSucceeded2011/7/24:01:03:26Rafael CabralSONY-210EInstalling Microsoft Visual C++ 2005 Redistributable (x86): F:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\RAFAEL~1\AppData\Local\Temp\vcredist_x86_2005.log"" "2011/7/24:01:03:28Rafael CabralSONY-210EInstallMicrosoft Visual C++ 2005 Redistributable (x86)FailedInstallation aborted, Result=16032011/7/24:01:04:14Rafael CabralSONY-210ERollbackAutodesk Material Library 2012 - Low ResolutionSucceeded2011/7/24:01:04:53Rafael CabralSONY-210ERollbackAutodesk Material Library 2012Succeeded2011/7/24:01:04:56Rafael CabralSONY-210ERollbackFaroSDKSucceeded2011/7/24:01:04:56Rafael CabralSONY-210ERollbackDirectX RuntimeFailedFailure is ignored, Result=16192011/7/24:01:04:57Rafael CabralSONY-210ERollback.NET Framework Runtime 4.0 Language PackFailedInstallation aborted, Result=16192011/7/24:01:04:57Rafael CabralSONY-210EPageOpenInstallCompleteDialog2011/7/24:01:05:01Rafael CabralSONY-210E=== Setup ended ===
2011/7/24:01:14:53Rafael CabralSONY-210E=== Setup started on SONY-210E by Rafael Cabral ===2011/7/24:01:14:53Rafael CabralSONY-210ELaunch 2011/7/24:01:15:12Rafael CabralSONY-210E=== Setup ended ===
2011/7/24:01:14:54Rafael CabralSONY-210E=== Setup started on SONY-210E by Rafael Cabral ===2011/7/24:01:14:54Rafael CabralSONY-210ELaunch 2011/7/24:01:15:12Rafael CabralSONY-210EPageOpenLaunchDialog2011/7/24:01:16:03Rafael CabralSONY-210EPageOpenLicenseDialog2011/7/24:01:16:08Rafael CabralSONY-210EPageOpenProductInfoDialog2011/7/24:01:16:24Rafael CabralSONY-210EPageOpenProductSelectionDialog22011/7/24:01:17:18Rafael CabralSONY-210EPageOpenFullProgressDialog2011/7/24:01:17:19Rafael CabralSONY-210EInstalling .NET Framework Runtime 4.0 Language Pack: F:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1046.exe /q2011/7/24:01:19:04Rafael CabralSONY-210EInstall.NET Framework Runtime 4.0 Language PackSucceeded2011/7/24:01:19:04Rafael CabralSONY-210EInstalling DirectX Runtime: F:\3rdParty\DirectX\DXSETUP.exe /silent2011/7/24:01:19:44Rafael CabralSONY-210EInstallDirectX RuntimeSucceeded2011/7/24:01:19:44Rafael CabralSONY-210EInstalling FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/7/24:01:20:12Rafael CabralSONY-210EInstallFaroSDKSucceeded2011/7/24:01:20:13Rafael CabralSONY-210EInstalling Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\RAFAEL~1\AppData\Local\Temp\_AID183.tmp\Media.mst"
2011/7/24:01:20:46Rafael CabralSONY-210EInstallAutodesk Material Library 2012Succeeded2011/7/24:01:20:48Rafael CabralSONY-210EInstalling Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="F:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\RAFAEL~1\AppData\Local\Temp\_AID183.tmp\Media.mst"
2011/7/24:01:21:28Rafael CabralSONY-210EInstallAutodesk Material Library 2012 - Low ResolutionSucceeded2011/7/24:01:21:28Rafael CabralSONY-210EInstalling Microsoft Visual C++ 2005 Redistributable (x86): F:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\RAFAEL~1\AppData\Local\Temp\vcredist_x86_2005.log"" "2011/7/24:01:21:29Rafael CabralSONY-210EInstallMicrosoft Visual C++ 2005 Redistributable (x86)FailedInstallation aborted, Result=16032011/7/24:01:21:57Rafael CabralSONY-210ERollbackAutodesk Material Library 2012 - Low ResolutionSucceeded2011/7/24:01:22:32Rafael CabralSONY-210ERollbackAutodesk Material Library 2012Succeeded2011/7/24:01:22:35Rafael CabralSONY-210ERollbackFaroSDKSucceeded2011/7/24:01:22:35Rafael CabralSONY-210ERollbackDirectX RuntimeFailedFailure is ignored, Result=16192011/7/24:01:22:35Rafael CabralSONY-210ERollback.NET Framework Runtime 4.0 Language PackFailedInstallation aborted, Result=1619
It told you to do this:
Have you done it?
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Installation Forum is at:
