Tried installing Navisworks Manage using different type of setups but I always get the same error. I have attached a screenshot for reference. Kindly help me out!
This is a problem with the Visual C++ Redistributable. You should uninstall it from Control Panel and then run setup again. If that doesn't work, install the VC++ manually, then see if the install will go. If that still fails, let me know and I can show you how to edit the setup.ini (instructions in my signature) to ignore this problem.
Good Luck!
