Installation & Licensing
*Pownall, Lori Beckett
Message 1 of 2 (296 Views)
Error creating client deployment
296 Views, 1 Replies
09-20-1999 07:08 AM
Jerry,
Before I wipe this drive, could it be a problem with the AutoCAD CD? I tried to copy this
same file from the CD onto a different computer and got the same error. However, I can copy the
existing file on the second computer to the original computer with no problem.
Also, the file system is NTFS on both systems.
Lori
"jerry milana [Autodesk]" wrote:
> Lori,
> Do you still get the CRC error when trying to copy the file? If you are, try booting your
> system in DOS, then try copying the file. This recommendation assumes that your file system
> is FAT. If your file system is not FAT or copying under a DOS boot did not work, it is time
> to bite the bullet and low level format your disk (back up your data first).
> Jerry
> Lori Beckett Pownall wrote:
> > Jerry,
> > I do apologize. I had no idea the two could be related! I have done a check disk. My
> > system does not have dual processors nor any of the boards/chip sets mentioned and I
> > don't have a super disk(and even if I did, I have rebooted repeatedly). I also
> > re-installed service pack 5, hoping that would help, but it didn't. I am still getting
> > the same error. Any other suggestions?
> > Thanks for the help!
> > Lori
> > > Lori,
> > > I assure you, I did read your entire message. The second half of your message simply
> > > gave me an insight as to WHY the first half is occurring. Had you not tried to copy
> > > the file like you did, that would have been my suggestion. Bottom line is that if
> > > you can not copy the file from the command line, setup will not be able to either.
> > > The fact that you are getting a CRC (cyclic redundancy check) error points to a
> > > system problem.
> > > Jerry
> > > > Jerry,
> > > > It looks like you latched onto the second thing I did & the error it
> > > > generated. The file I was trying to copy was from the AutoCAD200 CD, but I just
> > > > did that out of curiosity. Please re-read the first part of my original message.
> > > > There was a similar problem posted to this newsgroup back around the beginning
> > > > of June. The big difference between his system & mine is that he was installing
> > > > on a Novell
> > > > 5.0 server and I am installing on a NT 4.0 server with SP5. The machine is a
> > > > Gateway P5-166 single processor, but I will double check the mother board/
> > > > processor types with the listing in the one Microsoft article to see if perhaps
> > > > there is a match.
> > > > Thanks for your help!
> > > > Lori
> > > > > Lori,
> > > > > Check out the following Microsoft support documents:
> > > > > http://support.microsoft.com/support/kb/articles/Q186/7/70.ASP
> > > > > http://support.microsoft.com/support/kb/articles/Q187/9/41.ASP
> > > > > http://support.microsoft.com/support/kb/articles/Q196/9/75.ASP
> > > > > In summary, this is an operating system error that appears to indicate
> > > > > either an unregistered version of mfc42.dll or a hardware error such as a
> > > > > corrupted disc sector or controller error. Try running chkdsk after reading
> > > > > the above documents and see if that helps.
> > > > > Jerry Milana,
> > > > > Autodesk Product Support
> > > > > > I'm trying to create a client deployment setup of AutoCAD 2000 on a NT
> > > > > > 4.0 server running SP5. The installation creates an Image directory
> > > > > > along with a Data
> > > > > > and System sub directory. The data files are copied without any
> > > > > > problems
> > > > > > but as soon as the install program tries to copy system files I get the
> > > > > > following error Message:
> > > > > > "Setup could not copy the following file due to insufficient disk
> > > > > > space
> > > > > > ... D:\SYSTEM\mfc42.dll"
> > > > > > At this point it goes back to the beginning installation screen where
> > > > > > you tell it what directory to install in and wants to start all over. I
> > > > > > am logged into the server as Admin and have checked to make sure that
> > > > > > there is enough space on the server volume (3.1 GB). I even tried to
> > > > > > manually copy the .dll file and got the following error message when I
> > > > > > did:
> > > > > > Cannot copy MFC42: Data Error (cyclic redundancy check)
> > > > > > I read the earlier messages about the same problem but with a
> > > > > > different OS. Apparently, what was applicable there, isn't here or maybe
> > > > > > it was just all greek to me as the fix didn't make sense. I desperately
> > > > > > need to get this running as I will be out most of next week and don't
> > > > > > want to leave my clients hanging.
> > > > > > Thanks for any & all help!
> > > > Lori Beckett Pownall - County Coordinator for
> > > > Daviess Co. MO http://www.rootsweb.com/~modavies/daviess.htm
> > > > Warwick Co. VA http://www.rootsweb.com/~vawarwic/warwick.htm
> > > > List owner of MODAVIES-L, OKSEMINO-L, VAWARWIC-L & POWNALL-L
> > > > Home page http://members.home.net/s-lpownall/index.htm
> > > > A proud sponsor of RootsWeb!
*[Autodesk], jerry milana
Message 2 of 2 (296 Views)
Re: Error creating client deployment
09-21-1999 11:49 AM in reply to: *Pownall, Lori Beckett
Lori,
Try copying the file from the CD to a directory on another system. If that works, I think it is
safe to assume the CD is OKay. If it fails again, contact your dealer for a replacement CD as it
is conceivable that the CD has become physically damaged.
Jerry
> Jerry,
> Thanks,
> Lori
> > Lori,
> > Jerry
> > > Jerry,
> > > Lori
> > > > Lori,
> > > > system problem.
> > > > Jerry
> > > > > Jerry,
> > > > > on a Novell
> > > > > there is a match.
> > > > > Lori
> > > > > > Lori,
> > > > > > Jerry Milana,
> > > > > > > along with a Data
> > > > > > > problems
> > > > > > > space
> > > > > > > did:
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
