Installation & Licensing
Message 1 of 8
danyon
674 Views, 7 Replies
Error code 1603
Error 1603 during installation of Autodesk Maya 2013 plz..... Help
7 REPLIES 7
Message 2 of 8
Yannick.Karawa
in reply to: danyon
Please provide us the "install.log" file generated after the installation attempt under %tmp%.
Yannick Karawa
Message 3 of 8
danyon
in reply to: danyon
2013/9/13:17:45:38 USER USER-PC === Setup started on USER-PC by USER ===
2013/9/13:17:45:38 USER USER-PC Launch
2013/9/13:17:45:44 USER USER-PC === Setup ended ===
2013/9/13:17:45:40 USER USER-PC === Setup started on USER-PC by USER ===
2013/9/13:17:45:40 USER USER-PC Launch
2013/9/13:17:45:44 USER USER-PC PageOpen LaunchDialog
2013/9/13:17:45:48 USER USER-PC PageOpen LicenseDialog
2013/9/13:17:45:57 USER USER-PC PageOpen ProductInfoDialog
2013/9/13:17:47:22 USER USER-PC PageOpen ProductSelectionDialog2
2013/9/13:17:47:29 USER USER-PC PageOpen FullProgressDialog
2013/9/13:17:47:29 USER USER-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\Maya_2013_CEJ_Win_64-bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/9/13:17:47:33 USER USER-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/9/13:17:47:35 USER USER-PC PageOpen InstallCompleteDialog
2013/9/13:17:47:48 USER USER-PC === Setup ended ===
2013/9/13:17:51:13 USER USER-PC === Setup started on USER-PC by USER ===
2013/9/13:17:51:13 USER USER-PC Launch
2013/9/13:17:51:17 USER USER-PC === Setup ended ===
2013/9/13:17:51:17 USER USER-PC PageOpen LaunchDialog
2013/9/13:17:51:45 USER USER-PC PageOpen LicenseDialog
2013/9/13:17:51:53 USER USER-PC PageOpen ProductInfoDialog
2013/9/13:17:53:23 USER USER-PC PageOpen ProductSelectionDialog2
2013/9/13:17:53:57 USER USER-PC PageOpen FullProgressDialog
2013/9/13:17:53:57 USER USER-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\Maya_2013_CEJ_Win_64-bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/9/13:17:54:02 USER USER-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
Message 4 of 8
Yannick.Karawa
in reply to: danyon
Hi Danyon,
Try to manually remove the VC++ components from your computer from "uninstall or change a program" and reattempt the installation.
If it still fails, append the "setup.ini" file you use for the installation which is located in the same directory as the "Setup.ini".
Yannick Karawa
Message 5 of 8
TravisNave
in reply to: danyon
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
The prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 6 of 8
danyon
in reply to: Yannick.Karawa
Hi
I Removed VC++ From my computer But I got the Same error..
Message 7 of 8
danyon
in reply to: TravisNave
Hi....
I uninstall Visual VC++ Redistributable, But I got the Same error.Then I tried to Install VC++ 2008
Located in C:\Autodesk\Maya_2013_CEJ_Win_64-bit\3rdParty\x64\VCRedist\2008SP1. But I can't Install it too
It says "Error 1935.An error occurred during the installation of assembly Microsoft.VC90.ATL,version=
9.0.30729.4148",publicKeyToken="1fc8b3b9a1e18e 3b",processorArchitecture="amd64",type="win32"'."
What Should I Do...
Message 8 of 8
TravisNave
in reply to: danyon
See my post about editing the setup.ini to remove the check for this prereq.  That should get you installed at least.  But you will have to figure out how to get the C++ installed, regardless.
Autodesk Forums:
Administrator Productivity
