Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Error accessing subscription centre - Error #111
11 REPLIES 11
Message 1 of 12
jay_colcombe
719 Views, 11 Replies
When attempting to access the subscription centre i get the follwoing error;
We are sorry...        Subscription Help                                    There was an internal problem with the data submitted.  Please let the Autodesk Business Center know, error #111
Jay Colcombe
Autodesk Certified Instructor
11 REPLIES 11
Message 2 of 12
camilo.lemos
in reply to: jay_colcombe
Hi Jason and welcome to the forums.
It looks like at least one of your subscription contracts belongs to a reseller account. If you are a reseller, please contact our partner support team via the traditional means as the community managers on this forum do not have means to edit partner accounts.
Best regards,
Camilo Lemos
Message 3 of 12
in reply to: camilo.lemos
Hi I am getting the same error
I was able to access it yesterday and not today
I am not a reseller but did recently renew some subscriptions on some of our licenses.
Message 4 of 12
amanda.k
Hi Blake,
Welcome to the Community!
I have found your account and am working on troubleshooting it. As soon as it is corrected I will send you the log in information in a Personal Message.
Thank you for your patience and I apologize for the inconvenience!
Amanda Kinley
Community Program Manager
Message 5 of 12
I'm having the same issue trying to login to subscription center.
Could you help please?
Thank you
Ha habido un problema interno con los datos enviados. ComunĆ­queselo a Autodesk Business Center, error #111
PĆ³ngase en contacto con Ayuda de suscripciĆ³n.
Si desea descargar la actualizaciĆ³n del producto con su contrato anterior de Subscription, haga clic aquĆ­.
Message 6 of 12
I get error 111 trying to access the subscription center I need to get my whole system!!!!
I have a 3 year contract!!!
Message 7 of 12
DarrenP
try contacting your reseller so they can create a case with autodesk if you don't get a response on here
the problem seems to be on Autodesks end
DarrenP
Message 8 of 12
philip.s
My apologies for the inconvenience and David (dserral and david) .
As I've just made adjustments to both your accounts, can you please clear your browser cache and try logging in again? Are you able to get in?
For future reference, anyone facing the same issue can also contact our Subscription Center Support Team directly.
Message 9 of 12
I can get into subscription center but NOT download my software!
Message 10 of 12
philip.s
Thanks for verifying and as it appears to be caused by a data sync, I've made another backend tweak which should allow access shortly.
As a temporary workaround and while that processes, please download the software directly through Matt our Virtual Agent.
Please let me know if you continue to have issues so that I can investigate accordingly.
Message 11 of 12
koyoya.fuko2012
in reply to: amanda.k
dear Amanda please fix my account too koyoya.fuko2012@yhoo.com
Message 12 of 12
Darin.Green
Since you're able to access subscription center/Autodesk Account now, you can download the software from the Autodesk Virtual Agent
Once there, use the Download Links option to navigate to the application you need to download.
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, one they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
If this information was helpful, please consider using the Accept Solution
Administrator Productivity
