Installation & Licensing
Active Member
albertochispa
Message 1 of 6 (961 Views)
Error Installing Revit 2014: The library could not be installed.
961 Views, 5 Replies
02-10-2014 09:34 AM
Hello to everyone, specially the support crew.
I have been trying to install Revit 2014 for two days and it always fails when almost done with this message:
The library could not be installed/uninstalled. Please exit all runing application and try again.
When I chek the log file find several failures tha are ignored in the installation process:
.NET Framework Runtime 4.5 Language pack    Failed    Failure is ignored, Result=1619
DirectX® Runtime    Failed    Failure is ignored, Result=1619
Microsoft Visual C++ 2005 Redistributable (x64)    Failed    Failure is ignored, Result=1619
But this is the one that is aborting the installation:
Install    Autodesk Material Library 2014 - Low Image Library     Failed    Installation aborted, Result=1603
I have found several mates that have a similar failure but involving "downloading". This looks like is not my error, so I understand here in this log that I have no problem downloading, but installing.
I sincerely  appreciate the help from the support staff or a little help from my friends.
The log file is Attached above
jessica.t
Message 2 of 6 (936 Views)
Re: Error Installing Revit 2014: The library could not be installed.
02-10-2014 12:12 PM in reply to: albertochispa
Hi Alberto and welcome to the Autodesk Community!
Could you please take a look at these troubleshooting steps to help resolve the error? This solution may also be helpful.
Please "Accept as a Solution" if this post resolves your issue so that others with this same question can more easily find an answer. If not, please respond to this post with further details.
Thanks!
Jessica Thrasher
Active Member
albertochispa
Message 3 of 6 (928 Views)
02-10-2014 03:23 PM in reply to: albertochispa
Hello Jessica,
Thanks for your response.
Of course I have tried those troubleshooting steps, and all the others I could find here in the forum.
I have tried to uninstall all the elements who seemed to failure:
DirectX® Runtime
And all the Microsoft Visual C++ elements.
I also installed the Autodesk Service Pack, loged as an Administrator, disabled my Antivirus software, disable UAC in my Windows 7 (64b), etc..
I have not found any post about my failure: (not downloading issue)
In my Temp folder Revit appear several subfolders  but I do not know what to do with these.
Jessica, I wish I could "Accept as a Solution" your response but It was far from that. I have been tried all the chances I have found in the forum, but sadly I am starting to feel exhausted.
Anyway, I would thank you very much if you could guide me to try something else o try with somebody else who have solved a Library failure as mine.
Thank you so much.
Product Support
david.lau
Message 4 of 6 (913 Views)
02-11-2014 06:41 AM in reply to: albertochispa
What operating system, video card and bit are you using?
Can you try a browser download of the software?  If you have, can you send me the setup.ini file from the C:\Autodesk\"Revit 2014" folder?  I am going to hack out the Material Library from the install to get Revit installed?   Please note that if you don't have a certified system, Revit may not run.
David Lau
Active Member
albertochispa
Message 5 of 6 (909 Views)
02-11-2014 07:17 AM in reply to: albertochispa
Thanks a lot for your help, David.
I have finally uninstalled all my autodesk applications in case the libraries of 3dsMax or Autocad were involved in the failure. I have found some comments about similar problems and they have solved them uninstalling all about Autodesk. So my laptop is now being clear of your software, that I must say, it is being so long to achieve.
Now I am going to try again. I have cleaned the Temp folder and I will send you the setup.ini as soon as I finish to uninstall and install again from zero. I am afraid that if I can not solve this, maybe it is time to come back with Archicad, the bim software I have been using since years.
As for the information you ask:
ASUSTeK Computer Inc. (2012)
Windows 7 Home Premium
Copyright © 2009 Microsoft Corporation  (certified system, of cpurse, at least it is what they told me in MediaMarkt)
Service Pack 1
Intel(R) Core(TM) i7 CPU  Q 740 @1.73GHz
Memory 4GB
64Bits
ATI Mobility Radeon HD 5730, Memory 2768 MB
Thank you so much for your help David, I will send you the setup.ini file as soon as I get it.
Active Member
albertochispa
Message 6 of 6 (903 Views)
02-11-2014 10:13 AM in reply to: albertochispa
Failure Solved
Finally, installation succeed. The failure was solved uninstalling all autodesk products and all the hidden files and folders in C:, users, app data, common files, etc. Also removing the Autodesk folders in machine and user in Regedit of Windows. This solution was found in other forum but it would be nice to have here for others useres with similar problems.
I have installed the student version for 3 years license and now I will take the most of autocad 2014 and 3DMax.
Thanks a lot, David and Jessica for your support.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
