• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    mjcouch
    Error Code [-96.491.1006]
    106 Views, 8 Replies
    01-31-2012 06:51 AM
    My three Flexlm servers are reporting borrowed licenses for PC's that don't have a borrowed license for Revit Architecture. I have one laptop that does have a license but I get the error code [-96.491.1006] unable to return borrowed license. How can I clear my license servers to restore the correct settings and allow the return of the borrowed lic? NB: I have set my options file to prevent Revit borrowing but this is getting overridden by cascading ACAD Architecture suite licenses which keep stealing the Revit license!
    Any advice will be appreciated.
    ***Guru
    TravisNave
    Re: Error Code [-96.491.1006]
    01-31-2012 07:37 AM in reply to: mjcouch
    Borrowed licenses will show (linger) beside them in the server status enquiry.  If you do indeed have borrowed licenses but the computers listed do not have licenses borrowed for that product anymore, you can usually resolve this by launching the product again on those machines, borrow the license again, and return it.  If you have a stuck license on your laptop that will not return, you can simply just wait out the time period and it will expire.
    I assume you are running a redundant license model?  Such a model typically has issues like this because it has to update its reporting between the servers.
    My Top Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files | Search Autodesk Discussion Groups
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    mjcouch
    01-31-2012 07:46 AM in reply to: TravisNave
    I'm running distributed servers and using Environment variables to control the server selection, is that described as redundant?. Yes the license is stuck but it is an ACA using a Revit lic and I hadn't set a borrow time limit so the user booked it out for 30 days! With only three Revit lics and one tied up on a laptop I need to clear the error, the laptop doesn't even have Revit installed! Is there no way to clear it?
    Thanks for your input.
    ***Guru
    TravisNave
    01-31-2012 08:18 AM in reply to: mjcouch
    No, distributed is different than redundant.  I suspect that only one of your servers shows a stuck borrowed license then?  If so, send me a private message with the status enquiry pasted so I can provide you with a potential fix.
    **Master
    01-31-2012 10:12 AM in reply to: TravisNave
    mjcouch
    02-01-2012 04:11 AM in reply to: DarrenP
    Thanks, this is useful to remember, it certainly clears the client of the license but my server is still refusing to play ball.
    ***Guru
    TravisNave
    02-01-2012 06:56 AM in reply to: mjcouch
    Glad you are up and running!  :smileyhappy:
    **Master
    02-01-2012 06:59 AM in reply to: TravisNave
    have you tried a stop/start server on the start/stop/reread tab?
    mjcouch
    02-01-2012 07:13 AM in reply to: DarrenP
    Thanks to Travis and Darren for excellent help, I may just keep my hair from turning fully grey a bit longer!
