Installation & Licensing
New Member
mraxe
Message 11 of 12 (302 Views)
Re: Error Code -5.412.0
01-14-2013 01:05 AM in reply to: dbottomley
Hello for the second day I suffer with training license 3DS max.
Initially, the error was -96.491.0 after made an open port on the router error disappeared.
-5.412.0 Now and the next 20. Moreover, errors are issued instantly.
try to delete the file cascadeinfo, cas no avail.
For information on the two PCs is Litsense Network Manager
Debug from server.
10:34:54 (lmgrd) -----------------------------------------------
10:34:54 (lmgrd) Please Note:
10:34:54 (lmgrd)
10:34:54 (lmgrd) This log is intended for debug purposes only.
10:34:54 (lmgrd) In order to capture accurate license
10:34:54 (lmgrd) usage data into an organized repository,
10:34:54 (lmgrd) please enable report logging. Use Macrovision's
10:34:54 (lmgrd) software license administration solution,
10:34:54 (lmgrd) FLEXnet Manager, to readily gain visibility
10:34:54 (lmgrd) into license usage data and to create
10:34:54 (lmgrd) insightful reports on critical information like
10:34:54 (lmgrd) license availability and usage. FLEXnet Manager
10:34:54 (lmgrd) can be fully automated to run these reports on
10:34:54 (lmgrd) schedule and can be used to track license
10:34:54 (lmgrd) servers and usage across a heterogeneous
10:34:54 (lmgrd) network of servers including Windows NT, Linux
10:34:54 (lmgrd) and UNIX. Contact Macrovision at
10:34:54 (lmgrd) www.macrovision.com for more details on how to
10:34:54 (lmgrd) obtain an evaluation copy of FLEXnet Manager
10:34:54 (lmgrd) for your enterprise.
10:34:54 (lmgrd)
10:34:54 (lmgrd)
10:34:54 (lmgrd)
10:34:54 (lmgrd) pid 1116
10:34:54 (lmgrd) Detecting other license server manager (lmgrd) processes...
10:34:54 (lmgrd) Done rereading
10:34:54 (lmgrd) FLEXnet Licensing (v11.5.0.5 build 60835 i86_n3) started on k1 (IBM PC) (1/14/2013)
10:34:54 (lmgrd) Copyright (c) 1988-2007 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
10:34:54 (lmgrd) US Patents 5,390,297 and 5,671,412.
10:34:54 (lmgrd) World Wide Web: http://www.macrovision.com
10:34:54 (lmgrd) License file(s): C:\Program Files\Autodesk Network License Manager\ESEC2010rulicense.lic
10:34:54 (lmgrd) lmgrd tcp-port 27000
10:34:54 (lmgrd) Starting vendor daemons ...
10:34:54 (lmgrd) Starting vendor daemon at port 2080
10:34:54 (lmgrd) Using vendor daemon port 2080 specified in license file
10:34:54 (lmgrd) Started adskflex (pid 1524)
10:34:54 (adskflex) Unable to initialize access to trusted storage: 1
10:34:54 (adskflex) FLEXnet Licensing version v11.5.0.0 build 56285 i86_n3
10:34:54 (adskflex) Server started on k1 for: 85519ESEC_2010_0F
10:34:54 (adskflex) PLIST 85400MAYAMMR_2010_0F 85400MAYAMFS_2010_0F
10:34:54 (adskflex) 85400MAYAMMR1_2010_0F 85400MAYAMMR2_2010_0F 85400MAYAMMR3_2010_0F
10:34:54 (adskflex) 85400MAYAMMR4_2010_0F 85400MAYAMMR5_2010_0F
10:34:54 (adskflex) EXTERNAL FILTERS are OFF
10:34:54 (lmgrd) adskflex using TCP-port 2080
10:50:18 (adskflex) TCP_NODELAY NOT enabled
125Autodesk Education Suite for Entertainment Creation 201085519ESEC_2010_0F370-6001073418-Dec-201218-dec-2015
125Autodesk Maya 2010 Mental Ray85400MAYAMMR_2010_0F370-6001073418-Dec-201218-dec-2015
125Autodesk Maya 2010 Fluid Simulation85400MAYAMFS_2010_0F370-6001073418-Dec-201218-dec-2015
125Autodesk Maya 2010 Mental Ray 185400MAYAMMR1_2010_0F370-6001073418-Dec-201218-dec-2015
125Autodesk Maya 2010 Mental Ray 285400MAYAMMR2_2010_0F370-6001073418-Dec-201218-dec-2015
125Autodesk Maya 2010 Mental Ray 385400MAYAMMR3_2010_0F370-6001073418-Dec-201218-dec-2015
125Autodesk Maya 2010 Mental Ray 485400MAYAMMR4_2010_0F370-6001073418-Dec-201218-dec-2015
125Autodesk Maya 2010 Mental Ray 585400MAYAMMR5_2010_0F370-6001073418-Dec-2012
18-dec-2015
Debug from server.
10:34:54 (lmgrd)
10:34:54 (lmgrd)
10:34:54 (lmgrd)
10:34:54 (lmgrd)
125 Autodesk Education Suite for Entertainment Creation 2010 85519ESEC_2010_0F 370-60010734 18-Dec-2012 18-dec-2015
125 Autodesk Maya 2010 Mental Ray 85400MAYAMMR_2010_0F 370-60010734 18-Dec-2012 18-dec-2015
125 Autodesk Maya 2010 Fluid Simulation 85400MAYAMFS_2010_0F 370-60010734 18-Dec-2012 18-dec-2015
125 Autodesk Maya 2010 Mental Ray 1 85400MAYAMMR1_2010_0F 370-60010734 18-Dec-2012 18-dec-2015
125 Autodesk Maya 2010 Mental Ray 2 85400MAYAMMR2_2010_0F 370-60010734 18-Dec-2012 18-dec-2015
125 Autodesk Maya 2010 Mental Ray 3 85400MAYAMMR3_2010_0F 370-60010734 18-Dec-2012 18-dec-2015
125 Autodesk Maya 2010 Mental Ray 4 85400MAYAMMR4_2010_0F 370-60010734 18-Dec-2012 18-dec-2015
125 Autodesk Maya 2010 Mental Ray 5 85400MAYAMMR5_2010_0F 370-60010734 18-Dec-2012
18-dec-2015
Member
kens
Message 12 of 12 (73 Views)
02-25-2014 12:02 PM in reply to: hashim.mundol
Finally a solution. I just spent more almost three hours on the phone with Autodesk, acquiring new licensing files, reconfiguring lmtool, and so much more. I went to places in Windows that I did not even know existed, and I have MCSE Server 2003. I've looked all over the Autodesk communities and searched the Internet for that specific error code, and none of these posts ever showed up - always got the "could not find..." message. More than half a dozen emails between Autodesk and myself, 5 different complete uninstall/reinstall, including registry wipes.
Well, in any event. Thank you. I got rid of cascadeinfo.cas as you suggested, opened AutoCAD, and right about the point when I was expecting to see that error message again, suddenly my workspace opened up. Unbelievable - one simple file that really doesn't serve any necessary function.
I'm responding to the most recent email I received from Autodesk, and I am providing this link to her. Hopefully in the future, rather than going through all those hoops of fire, they can simply start here -Keep  ISimple  S*****
Thank again. Have a great day!
Ken Stevenson
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
