• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    Error Code 110 when activating Max 2012
    1147 Views, 19 Replies
    05-27-2012 11:33 AM
    The title pretty much says it all. When I try to activate my copy of 3DS Max 2012 I get the following error:
    "A License error has occurred. Contact your technical support representative for assistance. To help determine the nature of the problem, the error code is: 110"
    I click OK on the message window and than another window pops up saying:
    "The software license check out failed. Error 20"
    Why is it doing this and how can I fix it?
    thanks,
    - Patrick
    Please use plain text.
    Customer Service
    arlinpega.bibat
    Re: Error Code 110 when activating Max 2012
    05-27-2012 06:21 PM in reply to: pmcallister
    Hi pmcallister:
    Please send me your serial number through private message(envelope next to your account name at the top of this page).
    Thank you,
    Arlin Bibat
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    Active Member
    05-29-2012 05:19 PM in reply to: arlinpega.bibat
    I sent my information to you through a PM yesturday. Have you been able to solve the problem at all?
    thanks,
    - Patrick
    Customer Service
    arlinpega.bibat
    05-29-2012 06:28 PM in reply to: pmcallister
    Hi pmcallister:
    I have responded to your inquiry through private message with the following information:
    I checked on your serial number and it appears to be unregistered.Please register your serial number first through  www.autodesk.com/register. You may use the same user ID and password that you use in Education Community. As soon as you have it registered, you may follow through the instruction and activate.
    I checked today and the serial number is still unregistered.  If you can send me your personal information through PM, I can do it for you. However, please note that in order for me to activate, I will need request code.
    . Following are the steps to retrieve the request code:
    1. Run the program
    2. Pull down menu 'Help'
    3. Click on 'About'
    4. Click the Production Information button at the right hand corner
    5. Click on the Activate button
    6. On this page you will be able to view Product, Serial Number and Request Code
    Arlin Bibat
    TW | PI | YT | BLOG
    Active Member
    05-30-2012 06:44 AM in reply to: arlinpega.bibat
    I appricate all the help. I am at work right now and as such am unable to do anything with it now. When I get home tonight I will make to take care of this first thing and if I run into any trouble I will let you know.
    Thanks a bunch,
    - Patrick
    Member
    TheIce
    06-05-2012 03:51 PM in reply to: pmcallister
    i am having the same problem. every time i run my 3ds max, a window pops up and tells me that i must first activate this program before running it. and the only option available is "activate", the "run" option being disabled". then I get the same errors as mentioned above.
    I have to inform you that this has happened with 2011 and 2012 versions, and i cannot seems to figure it out. and I can't try the solution you proposed because I can't get into the program to get my product request code.
    pls, someone help. I am running out of ideas.
    New Member
    06-06-2012 06:43 AM in reply to: pmcallister
    when i clicked ok after error code 110 dialogue box it gives me "The software license chec out failed. Error 20." what sould i do?
    Active Member
    06-18-2012 06:59 PM in reply to: myufka
    Just a heads up guys I still haven't gotten mine to work.
    - Patrick
    Customer Service
    arlinpega.bibat
    06-18-2012 07:42 PM in reply to: pmcallister
    Hi pmcallister:
    Your serial number needs to be registered first, before you can have it activated. I sent you a private message with an alternative on how we can we can register your serial number. I will wait for your response.
    Arlin Bibat
    TW | PI | YT | BLOG
    Active Member
    06-20-2012 06:00 PM in reply to: arlinpega.bibat
    OK so somebody tell me how you got your request code because I am convinced that at this point it isn't actully possable to obtain one and you can't use your product without it. So I am stuck with no program.
    According to the note that appears when you hit the little ? button next to the "Enter Product Request Code" on this page https://registeronce.autodesk.com/prodreg/collectF​lexNetStandaloneParams!input.action I SHOULD be able
    (and I quote the help box that appears)
    "To access the request code, start the product (which I did). On the Registration-Activation page, click Activate (as I did. The picture bellow shows window that appears when I click activate). The request code is displayed at the top of the page."
    But as you can see there is NO REQUEST CODE that is displayed. And I just did this 5 seconds ago.
