• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Batavia-GmbH
    Error Code 0.1.0020 on AutoCad2004 running on Vista
    308 Views, 3 Replies
    08-04-2011 11:54 PM
    Dear Experts,
    Every now and then (two or three weeks) my notebook shuts down with a bluescreen and reboots. So far so good, everything works fine. But if AuCad happens to be in use during shutdown, I have to reauthorize the product within 7 days (error code 0.1.0020).
    ActivationCenter Europe won't send me any new codes anymore (which I fully understand) and told my to install the hotfix for SATA-Harddrives. But 1. I don't have a SATA-Harddrive, 2. the error code is a different one an 3. the hotfix is only recommended for Acad 2006 and higher! Can I try this patch with Acad2004, as they told me?
    Then I've found this post:
    "Martin, This error is caused when license data files become out of synchronization. This is often caused by software that restores files automatically and problems that cause ungraceful system shutdown. If you are using any type of system restore software or system imaging software configure it to preserve the contents of the following folder: -C:\Documents and Settings\All Users\Application Data\Macrovision\SafeCast\Product Licenses -- Jerry Milana, Autodesk Professional Services"
    Unfortunately I can only see that folder, but I can't acces it.
    I would be very grateful for any suggestion/help!
    Please use plain text.
    Product Support
    Re: Error Code 0.1.0020 on AutoCad2004 running on Vista
    08-08-2011 12:01 PM in reply to: Batavia-GmbH
    I would try using the 2012 trial to see if you get crashes anymore.
    AutoCAD 2006 is an older version and the older posts may not help much because we only support current versions + 3 versions back.
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
    *Expert Elite*
    TravisNave
    08-08-2011 02:34 PM in reply to: Batavia-GmbH
    Correct.  This product is not supported for use on Windows Vista or Windows 7.  Please reinstall on Windows XP or use the latest version of AutoCAD.  You cannot access the folders you specify because they are placeholders as Windows Vista/7 use a different folder struction for user profiles and program data.  The license scheme for AutoCAD 2004 is not compatible with this version of Windows because your version of Windows did not exist when AutoCAD 2004 was being developed.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    10-07-2012 10:15 PM in reply to: Batavia-GmbH
    On Windows 7 delete .dat file in filder "C:\ProgramData\Autodesk\Software Licenses"
