Installation & Licensing
giba_sjrp
Message 1 of 9 (1,091 Views)
Error Civil 3D 2012 with Windows Installer Win 7 64bits
1091 Views, 8 Replies
07-13-2011 08:10 AM
I made the migration to 3D Civil Infrastructure Design Suite Premium 2012, I downloaded the 64bit version and installation on a PC where Win 64bit 7 had Civil 3D 2012 installed, but before you install the suite removed the Civil 3D.
When installing the suite all programs have been added successfully, except Civil 3D, where it does not appear to run, nor the mode Imperial, Metric or as Brazil.
Since the installation remade countless times, but nothing to install Civil 3D, if the program you use most.
The only error that appears during installation is the "Windows Installer", which stops working, plus the installation is completed successfully, it is not.
Upgrades Since this program's windows, more continues to error, since disable it, but it is impossible to start the installation of the Civil because it requires Windows intall.
I'm just seeing a solution, to restore the system before you install the suite, the more that was not what I wanted.
Win 7 64Bits
16GB
Itenl Core i7 870 2.93GHz
Employee
alison.gangler
Message 2 of 9 (1,076 Views)
Re: Error Civil 3D 2012 with Windows Installer Win 7 64bits
07-14-2011 08:33 AM in reply to: giba_sjrp
From the information you included, it looks like Windows Installer needs to be repaired. Try the steps listed in this article:
Microsoft KB Article
I hope this helps,
Alison
___________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Alison Gangler
IPG - ICP Install Engineer
giba_sjrp
Message 3 of 9 (1,070 Views)
07-14-2011 09:45 AM in reply to: alison.gangler
Alison,
I've tried this several times, but nothing worked.
The installation is complete, but the shortcuts for Civil 3D imperial or metric or Brazil, are not installed or available.
At the exact moment that the shortcuts should be installed, "Windows Installer" to function, as shown in the picture is attached.
Thanks, Gilberto
Employee
alison.gangler
Message 4 of 9 (1,067 Views)
07-14-2011 10:07 AM in reply to: giba_sjrp
Hi Gilberto,
In this case, I suspect that the Windows Profile for this user account might have some issues. I would create a new user account with full admin permissions and install through that account. After the install has completed, you can then again login to the original account and try to launch the application from that account. If it also still proves to have problems, then you might need to run the application from the new account.
Please let me know how it goes.
Alison
Alison Gangler
giba_sjrp
Message 5 of 9 (1,063 Views)
07-14-2011 11:52 AM in reply to: alison.gangler
Alison,
The user I'm logged in has administrative privileges, I am attaching a picture for example.
You know how to run the "Acad.exe" with a particular profile, such as Civil 3D "Metric"?
Maybe this way I can create my own shortcut.
Gilberto
Employee
alison.gangler
Message 6 of 9 (1,050 Views)
07-15-2011 08:06 AM in reply to: giba_sjrp
Hi Gilberto,
In answer to your question, the C3D 2012 Metric shortcut has the following properties:
Target: "C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\acad.exe" /ld "C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\AecBase.dbx" /p "<<C3D_Metric>>"
Start in: "C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\UserDataCache\"
If you are experiencing issues with the profile, then you can run the steps to reset the user settings so that the Metric profile is set up correctly in the registry and on the drive:
http://beingcivil.typepad.com/my_weblog/2011/05/add-reset-user-settings-in-civil-3d-2012.html
Please let me now if this helps!
Cheers,
Alison
Alison Gangler
giba_sjrp
Message 7 of 9 (1,046 Views)
07-15-2011 09:27 AM in reply to: alison.gangler
Alison,
Unfortunately I could not make it work.
I did all the procedures that you sent and also the shortcut with the suggested path.
When you run the shortcut I get the following error message "No Profile name exists: <<C3D_Metric>> Will create profile with defoult settings.
I do not know what else to do, I am without using a Civil week.
Gilberto
giba_sjrp
Message 8 of 9 (1,041 Views)
07-15-2011 11:08 AM in reply to: giba_sjrp
Resolved,
that was the Kaspersky antivirus nevertheless complete the installation.
He was off and install mode has been completed.
Thanks for the help.
Gilberto
Employee
alison.gangler
Message 9 of 9 (1,039 Views)
07-15-2011 11:15 AM in reply to: giba_sjrp
Glad to hear that you found out what caused the behavior.
Cheers,
Alison
Alison Gangler
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
