Installation & Licensing
Error AdapplicationFrame.dll
7 REPLIES 7
Message 1 of 8
JustinCase1
7885 Views, 7 Replies
Installed Autocad 2012 and when starting I get this error message.
Fatal error Unhandled Delayload: AdapplicationFrame.dll
7 REPLIES 7
Message 2 of 8
TravisNave
in reply to: JustinCase1
Welcome to the Autodesk peer support forum!
As for your error, I would suspect it is caused by a problem in your .NET Framework subsystem.  You might try reinstalling the latest version of .NET Framework.  Keep in mind that 2012 is not compatible with Windows 8, so hopefully you are on a supported system.
Autodesk Forums:
Message 3 of 8
JustinCase1
Thank you but installed the latest .Net software 2 weeks ago.
Message 4 of 8
TravisNave
It is possible that it needs reinstalled.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Autodesk Forums:
Message 5 of 8
JustinCase1
in reply to: TravisNave
Ran your removal tool and reinstalled .net same results, Di I have to uninstall and reinstall autocad?
Message 6 of 8
TravisNave
You need to reinstall .NET Framework.  You should download and install the full redistributable from Microsoft's website.  Then you *might* have to do a repair install of AutoCAD.
Autodesk Forums:
Message 7 of 8
JustinCase1
Opps should have put this in there: I did reinstall the .net so will try the repair install
Message 8 of 8
JustinCase1
ok removed and reinstalled .net and reloaded autocad. System still gives same error.
Administrator Productivity
