Installation & Licensing
TravisNave
Message 11 of 27 (3,800 Views)
Re: Error -5.412.0 @ Error -4.132.0
05-18-2010 07:23 AM in reply to: alextong
This is one of those hot-button issues that should be tried in nearly every situation, as it seems to solve the majority of the problems with Autodesk software since 2010.
For Vista and Windows 7 users, the location of this file is:
C:\ProgramData\Autodesk\AdLM
The corrupt CascadeInfo.cas file will be recreated when you relaunch the software.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
ramihautasaari_eng
Message 12 of 27 (3,552 Views)
11-02-2010 06:58 AM in reply to: Darin.Green
Thank you very very much for the solution! :smileyvery-happy:
Deleting CASCADEINFO.CAS solved my problem completely.
I was having trouble starting Inventor 2010 (not starting, just started as a process for a couple of seconds) and AutoCAD Mechanical 2010 (server license error).
You saved me for re-installing Windows (which was the only solution I came up with when having this problem last time).
Br
Rami
Active Member
sdewitt
Message 13 of 27 (3,518 Views)
11-04-2010 11:44 AM in reply to: Darin.Green
Just wondering...  Do you know why this works?
Just an FYI...  If anyone is using Window 7 the file location of the .cas file is c:smileytongue:rogramData\Autodesk\Adlm
Member
frankaholic
Message 14 of 27 (2,322 Views)
10-20-2011 08:19 AM in reply to: TravisNave
This worked great for an -4.132 error with Revit MEP 2012!
Thanks everyone!
Frank
TravisNave
Message 15 of 27 (2,320 Views)
10-20-2011 08:47 AM in reply to: frankaholic
Just to elaborate, the -4 error means that you were out of licenses on your NLM server.  Freeing up a license by having someone else close their application or return their borrowed license will resolve this temporary issue.  Deleting the CascadeInfo.cas file will work, however, if for some reason the cascading of licenses are not working when you are out of one feature and it cannot cascade to another available license.
Help Improve the Autodesk Discussion Groups
If I was able to resolve your issue, please select the "Accept as Solution" option so that you can help fellow members quickly find solutions to their problems. Please add Kudos to a post if you were helped by a post that you did not author.
Member
frankaholic
Message 16 of 27 (2,317 Views)
10-20-2011 11:06 AM in reply to: TravisNave
The problem I was having did not have to do with available licenses. There were two licenses available, and the workstation next to mine was able to open and close revit with no error.
Further, I was able to use revit last week with no problems.
When I deleted the .cas file, the error went away.
-Frank
TravisNave
Message 17 of 27 (2,312 Views)
10-20-2011 12:04 PM in reply to: frankaholic
Yes, which is why I clarified the difference between the standard -4 licenses exceeded error vs. the cascade issue.  Thanks.  :smileywink:
Member
frankaholic
Message 18 of 27 (2,309 Views)
10-20-2011 12:18 PM in reply to: TravisNave
i see. Big thanks to you and everyone who contributed. i don't know how long i would of struggled with this!:smileyhappy:
-Frank
TravisNave
Message 19 of 27 (2,307 Views)
10-20-2011 12:22 PM in reply to: frankaholic
I am glad you are up and running.  Every little bit of helpful information is a good resource for someone else.  You never know what tidbit is going to fix someone else.  Feel free to pick our brains anytime and contribute any solutions you have.  That's what it's all about, my man!  :smileyvery-happy:
New Member
jfields
Message 20 of 27 (2,028 Views)
Error -4.132.0
01-18-2012 06:52 AM in reply to: alextong
I have this error -4.132.0 comes up when I launch REVIT 2012 and ACAD 2012. I looked for the .cas file in the directory but did not find it. Can anyone please provide information on how to resolve this error.
Respectfully,
Jfields
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
