• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    TravisNave
    Re: Error -5.412.0 @ Error -4.132.0
    05-18-2010 07:23 AM in reply to: alextong
    This is one of those hot-button issues that should be tried in nearly every situation, as it seems to solve the majority of the problems with Autodesk software since 2010.
    For Vista and Windows 7 users, the location of this file is:
    C:\ProgramData\Autodesk\AdLM
    The corrupt CascadeInfo.cas file will be recreated when you relaunch the software.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Please use plain text.
    New Member
    ramihautasaari_eng
    11-02-2010 06:58 AM in reply to: Darin.Green
    Thank you very very much for the solution! :smileyvery-happy:
    Deleting CASCADEINFO.CAS solved my problem completely.
    I was having trouble starting Inventor 2010 (not starting, just started as a process for a couple of seconds) and AutoCAD Mechanical 2010 (server license error).
    You saved me for re-installing Windows (which was the only solution I came up with when having this problem last time).
    Br
    Rami
    Active Member
    11-04-2010 11:44 AM in reply to: Darin.Green
    Just wondering...  Do you know why this works?
    Just an FYI...  If anyone is using Window 7 the file location of the .cas file is c:smileytongue:rogramData\Autodesk\Adlm
    Member
    10-20-2011 08:19 AM in reply to: TravisNave
    This worked great for an -4.132 error with Revit MEP 2012!
    Thanks everyone!
    Frank
    TravisNave
    10-20-2011 08:47 AM in reply to: frankaholic
    Just to elaborate, the -4 error means that you were out of licenses on your NLM server.  Freeing up a license by having someone else close their application or return their borrowed license will resolve this temporary issue.  Deleting the CascadeInfo.cas file will work, however, if for some reason the cascading of licenses are not working when you are out of one feature and it cannot cascade to another available license.
    Help Improve the Autodesk Discussion Groups
    If I was able to resolve your issue, please select the "Accept as Solution" option so that you can help fellow members quickly find solutions to their problems. Please add Kudos to a post if you were helped by a post that you did not author.
    Travis Nave
    Member
    10-20-2011 11:06 AM in reply to: TravisNave
    The problem I was having did not have to do with available licenses. There were two licenses available, and the workstation next to mine was able to open and close revit with no error.
    Further, I was able to use revit last week with no problems.
    When I deleted the .cas file, the error went away.
    -Frank
    TravisNave
    10-20-2011 12:04 PM in reply to: frankaholic
    Yes, which is why I clarified the difference between the standard -4 licenses exceeded error vs. the cascade issue.  Thanks.  :smileywink:
    Travis Nave
    Member
    10-20-2011 12:18 PM in reply to: TravisNave
    i see. Big thanks to you and everyone who contributed. i don't know how long i would of struggled with this!:smileyhappy:
    -Frank
    TravisNave
    10-20-2011 12:22 PM in reply to: frankaholic
    I am glad you are up and running.  Every little bit of helpful information is a good resource for someone else.  You never know what tidbit is going to fix someone else.  Feel free to pick our brains anytime and contribute any solutions you have.  That's what it's all about, my man!  :smileyvery-happy:
    Travis Nave
    New Member
    Error -4.132.0
    01-18-2012 06:52 AM in reply to: alextong
    I have this error -4.132.0 comes up when I launch REVIT 2012 and ACAD 2012. I looked for the .cas file in the directory but did not find it. Can anyone please provide information on how to resolve this error.
    Respectfully,
    Jfields
