Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Error -5.412.0 @ Error -4.132.0
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
For Vista and Windows 7 users, the location of this file is:
C:\ProgramData\Autodesk\AdLM
The corrupt CascadeInfo.cas file will be recreated when you relaunch the software.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Error -5.412.0 @ Error -4.132.0
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you very very much for the solution! ![]()
Deleting CASCADEINFO.CAS solved my problem completely.
I was having trouble starting Inventor 2010 (not starting, just started as a process for a couple of seconds) and AutoCAD Mechanical 2010 (server license error).
You saved me for re-installing Windows (which was the only solution I came up with when having this problem last time).
Br
Rami
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Just wondering... Do you know why this works?
Just an FYI... If anyone is using Window 7 the file location of the .cas file is c
rogramData\Autodesk\Adlm
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This worked great for an -4.132 error with Revit MEP 2012!
Thanks everyone!
Frank
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Just to elaborate, the -4 error means that you were out of licenses on your NLM server. Freeing up a license by having someone else close their application or return their borrowed license will resolve this temporary issue. Deleting the CascadeInfo.cas file will work, however, if for some reason the cascading of licenses are not working when you are out of one feature and it cannot cascade to another available license.
Help Improve the Autodesk Discussion Groups
If I was able to resolve your issue, please select the "Accept as Solution" option so that you can help fellow members quickly find solutions to their problems. Please add Kudos to a post if you were helped by a post that you did not author.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The problem I was having did not have to do with available licenses. There were two licenses available, and the workstation next to mine was able to open and close revit with no error.
Further, I was able to use revit last week with no problems.
When I deleted the .cas file, the error went away.
-Frank
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, which is why I clarified the difference between the standard -4 licenses exceeded error vs. the cascade issue. Thanks. ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
i see. Big thanks to you and everyone who contributed. i don't know how long i would of struggled with this!![]()
-Frank
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am glad you are up and running. Every little bit of helpful information is a good resource for someone else. You never know what tidbit is going to fix someone else. Feel free to pick our brains anytime and contribute any solutions you have. That's what it's all about, my man! ![]()
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Error -4.132.0
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have this error -4.132.0 comes up when I launch REVIT 2012 and ACAD 2012. I looked for the .cas file in the directory but did not find it. Can anyone please provide information on how to resolve this error.
Respectfully,
Jfields
