Installation & Licensing
atulvishwakarma
1261 Views, 5 Replies
Error [ -4,132.0 ]
Dear Sir,
I have received the following message when I open the Autocad Mechanical 2010 , on operating system window vista, window xp,
" A valid license Could not be obtained by the network license Manager
Error [ -4,132.0 ]"
Kindly send the solution of this problem.
Thanks & Regards
Atul Vishwakarma
5 REPLIES 5
in reply to: atulvishwakarma
-4 indicates that you already reach the number of license used on your server.
"-4 Licensed number of users already reached."
Go to your server in do a "Perform status enquiry" to see who use AutoCAD Mechanical 2010.
Franck Hervet
Dear Sir,
Thanks ,
when I double click on ACM2010 ( network version) Icon to open it ,
It show the Error [-4,132.0] or Application open and terminate.
using operating system Window 7, Window XP, Vesta
pl. send the solution
Thanks & Regards
Atul Vishwakarma
Dear Sir,
Thanks ,
when I double click on ACM2010 Icon to open it ( network version under subscription),
on the same computer ACM2009 is running successfuly it pick the license from the same server
Thanks & Regards
Atul Vishwakarma
As Franck indicated, -4 means that you are out of licenses. You need to verify on your license manager who is using your licenses. You will be unable to launch your software until you free up a license.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Dear Sir,
Thanks for Help
but I have solved this Problem by deleting this File "CASCADEINFO.CAS"
not ACM is running Fine.
Thanks & Regards
Atul Vishwakarma
Administrator Productivity
