• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    Osi_turk
    Re: Error 2738 when installing AutoCAD 2012
    12-08-2011 08:07 PM in reply to: coreyiyican
    Hello everyone. i know this problem and solution too ))) please fallow this steps.
    first of all you have to delete the relevant registry entries and re-register the DLL.
    Please make sure you back up the registry/system before you make any changes to the registry (how u can look at from microsft official site)
    To delete the registry, please run following commands with elevated privileges
    On Windows 7/64 bit System
    1-) reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f
    2-) reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f
    u must delete both
    optional if you have 32 bit win7
    On Windows 7 32 bit
    To Re-register the DLL please run following commands with elevated privileges
    make copy+paste one by one
    On Windows 7 64 bit System
    c:\windows\syswow64\regsvr32 vbscript.dll
    c:\windows\system32\regsvr32 vbscript.dll
    On Windows 7 32 bit (optional for 32 bit win7)
    this step is so important. if u want to solve then you have to trust me. If you had McAfee Antivirus in the past (even if you have unistalled it might leave some trace)
    please use this tool to remove it completly.
    http://download.mcafee.com/products/licensed/cust_support_patches/MCPR.exe
    now intsall again. it will work, be sure )))) if you had activation problem after install then write me again. i know that slotion too...
    Best Regard
    Osman from Turkey
    Please use plain text.
    New Member
    03-02-2012 09:40 AM in reply to: coreyiyican
    Try "Fix Reg Cleaner", download it for free, you only buy it if you want. It worked whit me, uninstalled autdesk review, tough, after still did not installed autodesk.
    New Member
    06-29-2012 10:23 PM in reply to: coreyiyican
    hello,
    my autodesk content service couldn't be uninstalled....even in the syetem safe mode..
    also 2738 error...how can i make it??   also the regedit i had already deleted the terms..but it didn't work.....0 - 0
    New Member
    06-29-2012 10:30 PM in reply to: Osi_turk
    I did't find a \{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f in the HKCU just in HKCR!! how?
    New Member
    10-12-2012 01:54 PM in reply to: coreyiyican
    That doesn't work... i have tried everything. i try to uninstall it from my programs and i get a package error 2738. i try to download acad 2013 and even tried 2012 and still error 2738.. if theres a major issue with the service package.. why in the world is it still there. i needs to be fixed and i really need this program for my computer because im taking class and we are using it. i have tried to do everything possible. revo cleaner, i still get the error.
    New Member
    10-13-2012 07:37 PM in reply to: bhardman90
    The point is that i fixed it very stupidally before. But i don't remember what i've done and i don't have the program anymore. it doesn't seem to be a problem with the program. I remember now! If you're on windows you have to configure something like full admin rights or. Or something like, it's a windows configure, anyhow. You have to allow some special install or special full admin feature for install (control panel). And that's it. I cannot help you more because since i've changed OS for Ubuntu. I had enough of all the Microsoft Crap. Sorry for that but, it's the ****ing right answer. Best regards-
    New Member
    11-17-2012 12:58 PM in reply to: Osi_turk
    Thanks for your help Osman! The reg delete functions for HKCU did not apply in my case, these could not be found, but the McAfee uninstall seems to have done the trick.
