Installation & Licensing
hvillagran
3706 Views, 5 Replies
Error 20
Hello everyone,
Someone in the Area discussion group recommended me to post this here. I have a problem. When I try to start my trial version of 3ds max design I get the following error:
“Software License Checkout failed. Error 20”
Now, I have tried multiple ways to fix this already. I already renamed the cascade file in the adlm folder, I even moved the file to another location (It does not recreate the file afterward eitherway). I also changed the FLEXLM service from manual to automatic and vice versa, still no progress. I also reinstalled several times as well.
Does someone know if there is another way to fix this? I bought this computer from someone at school and I’m trying to install the trial version of 3ds max design in it. I have reason to believe the previous owner had a copy of either 3ds max or 3ds max design, so if everything fails is there any way to remove previous licenses so I can install this as a trial at least? I think that is what is causing the problem.
Furthermore, 3ds max won’t even start and crashes at launch. However, I don’t get the license error with this software.
Thank you for your time.
PS. This is a laptop btw, and I'm trying to install a stand alone trial license I don't think the previous owner used it with network liceneses either. Edited by: hvillagran on Apr 2, 2010 3:36 PM
5 REPLIES 5
If Autodesk 3ds Max and Autodesk 3ds Max Design were previously installed as a trial and that trial period has completed there may not be much we can do to undo that.
Try this:
  • 1. Completely uninstall all Autodesk software by following this Technical Solution:
http://support.autodesk.com/getdoc.asp?id=TS45252
  • 2. Re-Install Autodesk 3ds Max and Autodesk 3ds Max Design as Stand-Alone.
  • 3. Test Start Autodesk 3ds Max and Autodesk 3ds Max Design.
What is the result?
Douglas Lauritsen, Autodesk Product Support
Douglas Lauritsen
Support Specialist
Product Support
Autodesk, Inc.
bmf311
in reply to: DouglasLauritsen
I've had the same problem with my software as well and I actually uninstalled the product and re-installed it and still I recieve the same error. What can I do to fix this issue?
Thank you
info
in reply to: bmf311
I have the same problem...
Is ther a good soluiton for this problem??
Before i try to solve it and take me 2 days or something...
Thanks!
Tags (1)
That uninstall link, http://support.autodesk.com/getdoc.asp?id=TS45252, is gone and redirects to a home page that offers no information about this topic.
P.S. I am having the same problem, Error 20, and I have spent HOURS trying to find anything about it on Autodesk.com, and there doesn't seem to be a solution.  Once Autodesk has your money, it's very hard to get help from them.  The Live Chat option seems to never be available once they have your $.
@philip.j.davenport
Welcome to the community..
In the future you may want to start a new posting instead of replying to one that is 5 years old..  Meaning your reply may not been seen..
Follow the information as I pointed out in this posting: http://forums.autodesk.com/t5/installation-licensing/import-request-fail/m-p/6024203#M122422
Mark Lancaster
Administrator Productivity
