• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Error 20. THe software license check out failed
    1677 Views, 2 Replies
    12-12-2012 04:36 AM
    Is the only solution to reinstall 3ds Max? Im using Win7, 64 bit.
    Please use plain text.
    Product Support
    Re: Error 20. THe software license check out failed
    12-12-2012 11:07 AM in reply to: pmoraes_
    TravisNave
    12-13-2012 08:33 AM in reply to: pmoraes_
    David,
    Can you re-check your link?
    In the mean-time also look here:
    http://area.autodesk.com/forum/autodesk-3ds-max/installation---hardware---os/the-software-license-ch...
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
