Greetings
I'm reciving this error while I try to install ACAD student edition on my PC.
I do have win7 64bit system. I tried to install different versions, 2010, 2012, 2013, 64 and 32bit versions etc.
Anyone else having the same problem?
You will need to post your installation log files. 32-bit versions will not install on 64-bit Windows 7.
@Anonymous
Welcome to the community...
We need to see your actual installation log file so we can determine the root cause.
Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous
Mark Lancaster
Hello. If you search google on 1723 you will see you are likely having a windows error. This seems likely to be something connected to a disconnect in your Windows system. Possibly uninstall your Microsoft C++ from your machine before you run your installation. There will be multiple versions on your system, I would remove all and then try to install AutoCAD.
Thank you for taking part in our community!
