Installation & Licensing
Error 1723 AutoCAD 2012 Install in Sony Vaio VGN-SR590T Windows 7 64 HELP!
1 REPLY 1
4263 Views, 1 Reply
Hello, i get the following error
In english:
Error 1723. There is a problem with this Windows Installer package. A DLL required for this install to complete could not be run. Contact your support personnel or package vendor.
In spanish:
Error 1723. Hay un problema con este paquete de Windows Installer. Hay una DLL que se requiere para completar esta instalación que no se puede ejecutar. Póngase en contacto con el personal de soporte técnico o el proveedor del paquete.
I click ok, and the next screen tells me
In english:
Fatal error during installation #343 failed to run AdskExecuteSequence.
In spanish:
Error irrecuperable durante la instalacion #343: error al ejecutar AdskExecuteSequence
then:
In english:
Failed to initialize AutoCAD 2012.
In spanish:
Error al inicializar AutoCAD 2012.
The computer has Windows 7 64bit sp1, directx 11, windows installer 4.5, all microsoft updates and AutoCAD 2008 64bit well installed. I have turned off the antivirus and the antispyware, I have also unsuccsefully tried to install it in safe mode.
Can the Vaio proprietary software be the cause of it? if it is, how can i turn it off during install?
This install is for a big client, that was supposed to be quite easy but i have been trying for 3 days now and i dont know what else to do.
Please HELP!!
1 REPLY 1
camilo.lemos
Hi Saul.
Can you please have a look at the solution posted on this thread and let us know if it works for you please?
Thanks!
Camilo Lemos
Administrator Productivity
