Installation & Licensing
Error 1606 when downloading Revit 2013
1 REPLY 1
469 Views, 1 Reply
Yesterday I downloaded Windows 8 for my MacBook Pro. Everything else seems to be working fine, but when I tried downloading Revit the same error message comes up while it is still determining installation requirement. It says Error 1606: Could not acces network location \\psf\Home\Documents. I tried going to HKEY LOCAL MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders and made sure there was a Common Document there and there was. Anyone that can offer any help would be greatly appreciated. I don't know whether I should just call someone or keep searching online. Thanks in advance
1 REPLY 1
david.lau
The error points to this issue:
http://upandready.typepad.com/up_and_ready/2013/05/1606-error-autodesk-2014-installation-product-ini...
I would re-build the the partition and use boot camp for best performance of Revit instead of using Fusion of Parallels.  This is basically re-installing Windows.  This should solve the problem above if you can't hack the registry.
http://upandready.typepad.com/up_and_ready/2013/03/parallels-fusion-boot-camp-autodesk-products.html
David Lau
Administrator Productivity
