• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    tkpolak
    Error 1606: Could not access network location bin.
    1987 Views, 2 Replies
    08-30-2011 07:01 AM
    Hello.
    When installator is computing required disc space the following error pops up:
    I checked Windows help centre, my registry and all the shell's and things (registry) described there are ok.
    I tried this with Maya 2011 x64 on my x64 system. Help anyone? This is f***** not cool...
    Please use plain text.
    Product Support
    Re: Error 1606: Could not access network location bin.
    08-30-2011 10:45 AM in reply to: tkpolak
    Can you check out this post?
    http://forums.autodesk.com/t5/Installation-Licensing/Error-1606-Could-not-access-network-location-bi...
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
    New Member
    tkpolak
    08-30-2011 10:49 AM in reply to: david.lau
    well yes I checked it, however it regards already installed maya,
     "(replace the xxxxxxxxx with the path where Maya 2011 is installed)
    msiexec /qb /X {887CB4A1-5DB4-4924-A2C6-CDCB72376CC7} INSTALLDIR=”xxxxxxxxx”
    so what can I do? do the same thing for not-yet-installed maya making up the install directory? dunno :c
