Installation & Licensing
Product Support
hashim.mundol
Message 1 of 10 (9,493 Views)
Error 1606.Could not access network location bin maya 2011 64bit Uninstall
9493 Views, 9 Replies
10-07-2010 12:36 AM
Recently we had reported issues regarding uninstalling Maya 2011 on 64 bit OS.
Following Error was shown during the Uninstall Process.
One Work around is to use the following msiexec command
msiexec /qb /X {887CB4A1-5DB4-4924-A2C6-CDCB72376CC7} INSTALLDIR=”xxxxxxxxx”
 (replace the xxxxxxxxx with the path where Maya 2011 is installed)
 Important parameter for the work around is INSTALLDIR=”xxxxxxxxx”
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Active Member
Foobartender
Message 2 of 10 (9,315 Views)
Re: Error 1606.Could not access network location bin maya 2011 64bit Uninstall
11-08-2010 07:54 AM in reply to: hashim.mundol
That workaround doesn't work for me.
In ran
msiexec /qb /X{02C4BEE3-863A-41CD-8EDB-D90B04795509} INSTALLDIR="C:\Program Files\Autodesk\Maya2011"
and got the same error.
The GUID is for x64 SP1 Subscription Advantage Pack which was installed from a deployment created by the installer.
I first noticed this bug with Hotfix 2, the initial release worked fine. I didn't try Hotfix 1. So it's a regression that came with Hotfix 1 or 2. I already filed a bug report about it about 3 month ago. Please fix it. Being unable to uninstall Maya would hinder deploying the next update, so I haven't deployed any Hotfixes/SP1 yet, but totally would like to.
Product Support
hashim.mundol
Message 3 of 10 (9,268 Views)
11-10-2010 05:20 AM in reply to: Foobartender
Please try INSTALLDIR="C:\Program Files\Autodesk\Maya2011\"
note:the trailing \
Hashim Mundol
Active Member
Foobartender
Message 4 of 10 (9,265 Views)
11-10-2010 05:35 AM in reply to: hashim.mundol
I tried ...\Maya2011 and ...\Maya2011\bin with and without trailing backslash. Did not work.
Product Support
hashim.mundol
Message 5 of 10 (9,258 Views)
11-10-2010 06:37 AM in reply to: Foobartender
Try to run the Maya2011.msi from the deployment image folder.
Hashim Mundol
Active Member
Foobartender
Message 6 of 10 (9,220 Views)
11-12-2010 05:37 AM in reply to: hashim.mundol
Running msiexec /x \\path\to\Maya2011.msi produces the same error, also with INSTALLDIR parameter.
Just running the MSI interactively and choosing remove works. However, I'm not so keen on doing that with 80 workstations, so that doesn't solve my problem.
I've had log files created of the uninstallation attempts and will take a look at them when I find some time. Maybe I can find an important property that isn't set in unattended mode.
New Member
rabbs_79
Message 7 of 10 (9,201 Views)
11-12-2010 10:48 PM in reply to: hashim.mundol
Try the following instead:-
msiexec /qb /X {887CB4A1-5DB4-4924-A2C6-CDCB72376CC7} ARPINSTALLLOCATION=”xxxxxxxxx”
A custom action that runs only during uninstall sets INSTALLDIR to the value of ARPINSTALLLOCATION, which is blank during uninstall.  So while you can set the INSTALLDIR property on the command line, it is overwritten with the value of ARPINSTALLLOCATION before it can be used.
Active Member
Foobartender
Message 8 of 10 (9,100 Views)
11-18-2010 09:08 AM in reply to: rabbs_79
Great, that works. Thank you very much.
New Member
vickytronz
Message 9 of 10 (8,235 Views)
03-07-2011 04:04 AM in reply to: hashim.mundol
hi sir,
can u please explain a bit basic,
how to run msiexec command.
and this issue occured when there was a power failure when installing autdesk maya 2011.
the next time i tried, this issue occured. im in a situation not able to format my os. so plz help me solve '
this problem
thanks :smileyhappy:
fredquach
Message 10 of 10 (2,331 Views)
01-26-2013 12:20 AM in reply to: hashim.mundol
I have a similar error 1606 message while trying to install Autodesk Entertainment Creative suite for The Window side installation via Mac Boot Camp. The Mac side's installation has no problem. A search online seems to suggest problem with the registry. I reinstall Windows 7 just to make sure I start with a clean OS and still got the same error message. Another the solution suggested is to disconnect the internet, which seems to take care of this error message, but I end up with "not enough space" issue. the partition I made for the Window has 138-GB. I then try to test out on a different PC only machine, I got exactly the same thing.
Fred
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
